I have removed iTunes.indigoPlugin and several other plugins I don't use and placed them in a 'plugins (disabled) Copy' folder so they don't show up.
Do I need to reinstall iTunes? and is the other error on line 1622 also associated with iTunes?
- Code: Select all
10 Jan 2018, 20:46:56
Installing and enabling plugin EPS - Homebridge Buddy v1.0.1
Loading plugin "EPS - Homebridge Buddy 1.0.1"
Starting plugin "EPS - Homebridge Buddy 1.0.1" (pid 27834)
Started plugin "EPS - Homebridge Buddy 1.0.1"
EPS - Homebridge Buddy Automatically creating and configuring the first Homebridge server
SQL Logger creating table device_history_1623570568 for "Homebridge for Indigo"
EPS - Homebridge Buddy Building configuration for 'Homebridge for Indigo'
EPS - Homebridge Buddy Error
# WARNING #
# You have 128 items for Homebridge but it only supports 99, you #
# will be unable to use some of your items! #
# SUMMARY #
# Devices for Homebridge to parse : 203 #
# Included devices that Homebridge can use : 128 #
# Devices over 99 that won't work : 29 #
EPS - Homebridge Buddy Error Exception in plugin.buildServerConfig line 4234: 'key itunes_control not found in dict'
CODE: if server.pluginProps["itunes_control"] == 1:
EPS - Homebridge Buddy Error Exception in plugin.homebridgeSaveConfig line 1622: Expecting object: line 23 column 29 (char 561)
CODE: json_data = json.loads(config)
EPS - Homebridge Buddy Starting the Homebridge server 'Homebridge for Indigo', do not try to use Siri until you get a message that the server has started
# WARNING #
# SUMMARY #
EPS - Homebridge Buddy EPS - Homebridge Buddy is loaded and ready to use
