Yamaha RX Plugin - a/v receiver control
Tue Jan 02, 2018 1:23 pm
jltnol offline
Re: Yamaha RX Plugin - a/v receiver control
Hey Jay
So I ended up with the RX-A3070 and am using the RX-Vx73 Series version of the plugin. The plug didn't "auto find" the receiver, but all I did was manually enter the IP address and the rest went as planned.
From what I can tell, all of the prescribed action groups work just fine, including the "Play Net Radio Station". While I didn't go thru every single input, the ones I have connected to the receiver work perfectly, but when I select an AV input that has nothing connected, the following loops in the Event Log until I switch it to an input that does have something connected.
Action Group Set Input
Error cannot update device state for key input to value AV7 (invalid enumeration value)
Again, thanks for everyone's help on this. Having read all the threads here, I was a bit concerned that Yamaha might have different IP protocols for different receivers... and they may... but the RX-A3070 works just fine, and I'd even go out on a limb and based on my limited experiment, say the RX-A1070 does as well.
Its a beautiful day in Indigodomo Land! Thanks again for all the great work of everyone involved.
Wed Jan 10, 2018 9:13 am
chief42 offline
I'm using a RX-A870 with the RX-Vx73 plugin model and it works great. The plugin found my receiver on the network and all the functions seem to be working. Thanks for the all the hard work...This is exactly what I needed.
Thu Jan 11, 2018 11:11 am
amannone offline
Has anyone tried the plugin with an RX-A770? I'm contemplating a receiver upgrade as my RX-V473 doesn't do 4K at 60Hz and it's 30Hz makes my eyes sad.
As an aside, thank you to everyone who's worked to make this plugin. I really love being able to control my receiver thu Indigo.
-Andrew
Fri Jan 12, 2018 4:02 pm
jltnol offline
Hey Andrew
I know this will be of little help, but the RX-A3070 I have and RX-A2070 both have the same users manual, so I'd feel good in saying that between these two units, they are the same except for the power output. I did check the RX-A1070, and it too seemed to work ok. So, my half-assed point here is that my guess is that any RX-Ax70 model will work.
Tue Jan 16, 2018 3:22 pm
amannone offline
Thanks, jltnol!
Thu Feb 08, 2018 1:04 pm
In theory this $225 refurb TSR-5810 should work with the plugin. Maybe? I dunno. Just in case you do:
https://electronics.woot.com/offers/yam ... v-receiver
SmartThings refugee & happy to be on Indigo now.
Mac OS 10.12.6 on a i5 MBP running Harmony Hub, Hue, DomoPad, Dynamic URL, EPS Device Extensions, HomeBridge Buddy, Smart Dimmer, MatplotLib, Plex, Scale Adapters, uniFAP, Wunderground, Airfoil Pro.
Tue Feb 27, 2018 9:50 am
That 5810 is on sale again on woot. https://electronics.woot.com/offers/yam ... receiver-1
Anyone got one working with the plugin?
Wed May 09, 2018 7:36 am
It's back on sale again on woot. Anyone have one of these 5810s?
