LED Simple Effects Plugin
Wed Dec 28, 2016 8:39 pm
GlennNZ offline
Hi all,
Announcing a very simple new Plugin -
LED Simple Effects
For Indigo 7
Plugin Store:
https://www.indigodomo.com/pluginstore/131/
https://github.com/Ghawken/Indigo-SimpleLED
Enables the Fibaro RGBW pre-programmed color cycles to be selected as an Action Group.
(yes, yes - you can do this already with Z-wave modify config action command - once you know the parameters and the settings - however this simplifies the process)
(I did mention it was a simple plugin - didn't I?)
The Plugin - essentially doesn't run unless a action command/group is executed.
The image below are the current options - essentially for the Fibaro RGB, AeonLabs LED Bulb ZW098 and AeonLabs LED Strip ZW121
These are the pre-programmed Fibaro modes - so there is no Z-wave communication during the light changes - simply this command to start and/or end the process. In my mind the various default modes cover most basic usages and limits any Z-wave traffic issues that might occur with other solutions.
Update 0.0.6
As promised support for Aeon Labs RGB Bulbs (ZW098)
(Mainly for firmware 1.4 - as can't test others)
Similar Modes but also add dialog for colour chooser/selected see below
Glenn
Thu Dec 29, 2016 11:16 am
yassi offline
Re: LED Simple Effects Plugin (for Fibaro RGBW)
HI Glenn,
this is cool.
I wanted to give it a try, but when I create an action group I can't select the device, no device available.
I have my Fibaro RGBW running with the "LED Light Manager" plugin, have the devices (as separate colors, composite and white already in Indigo).
Am I missing something?
Yassi
Bildschirmfoto 2016-12-29 um 18.08.21.png (241.16 KiB) Viewed 8182 times
Bildschirmfoto 2016-12-29 um 18.13.01.png (66.23 KiB) Viewed 8182 times
Thu Dec 29, 2016 1:58 pm
GlennNZ offline
yassi wrote:
HI Glenn,
this is cool.
Yassi
I guess you are on Indigo6 - given the write device info to Log button?
Sorry - Indigo 7 only as uses the new device filtering - which is why unfortunately you don't see any devices!
:D
Glenn
Fri Dec 30, 2016 12:28 am
yassi offline
Glenn, sorry, didn't saw it's for Indigo 7 only.
Ok, I've bought the upgrade yesterday, will upgrade today.
Thx,
Yassi
Fri Dec 30, 2016 5:35 am
yassi offline
Glenn, it's working, cool stuff!
Yassi
Fri Dec 30, 2016 5:50 am
GlennNZ offline
Good to hear.
Will add support for AeonLab LED bulbs predefined modes soon.
Glenn
Fri Dec 30, 2016 9:36 am
yassi offline
Cool.
I don't own them (only Hue's), but I appreciate this!
Yassi
Sat Dec 23, 2017 4:09 am
mwoodage offline
Just downloaded this today - it brilliant, thank you :D
Sat Dec 23, 2017 10:04 am
This works great! A handy way for me to use the strip for some highly visible notifications. I didn't even know there WERE presets in the Fibaro.
Thanks for a fun toy at Christmastime!
Fair warning: that LPD preset might trigger a seizure in those sensitive! That's some high speed flashy lights.
Sat Dec 23, 2017 10:45 pm
agame offline
Never got around to adding support for the AEOTEC RGBW globes? Damn...gonna be a white Christmas I guess. :idea:
Sat Dec 23, 2017 11:02 pm
GlennNZ offline
Give me 10 minutes.... and I will see what can do...
(was mostly ready to go just waiting a indigo buglet fix)
G
Sun Dec 24, 2017 1:25 am
GlennNZ offline
Update to version 0.0.6
Adding support for Aeon Labs Bulbs .
Sun Dec 24, 2017 3:47 am
agame offline
\oh wow! fantastic. Thanks so much!!!
Sun Dec 24, 2017 4:08 am
agame offline
in case anyone else is motivated to xmasify their bulbs tonight, there's a very minor UI bug (the colour list in the menu is cropped on the initial view). Closing the configuration and reopening gives access to all the colours. so good!
Sun Dec 24, 2017 4:31 am
GlennNZ offline
Yep - or you can grab and resize the window when needed.
There is code somewhere to set the window size (should have it big enough for everything - even if color chooser list not shown) - but for life of me couldn’t find it in the limited time I had!
Will update soonish.
Glenn
