- Posted on
Fri Feb 09, 2018 9:30 am
joel.snyder
offline
Peter:
Here is the debug with both Z-Wave on and plugin on.
The first button press is 1-OFF; the second is 4-ON.
Looking at these, I wonder if this controller needs some programming first. It doesn't have a switch embedded, but button 1/ON and 1/OFF definitely does more than buttons 2, 3, 4 ON/OFF.
I don't know if it's relevant, but the time between Z-wave received and plugin debug printout seems to be long, on the order of 2 seconds. Perhaps there's a timer that is firing after incomplete message expected?
Z-Wave Debug RCVD nodeInfoFrame: 01 15 00 49 84 12 0F 02 01 00 85 2D 7C 77 82 73 86 72 91 EF 2B 2C E6
Z-Wave Debug RCVD basicSetState: 01 09 00 04 08 12 03 20 01 00 CA
Z-Wave Debug . . basicSetState: node 018, endpoint None, value 0 (no node dispatch)
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 12 03 20 01 00 C2
Z-Wave Debug RCVD requestReply1: 01 09 00 04 00 12 03 2C 02 00 CD (hex)
Z-Wave Scene Controller Debug -----
Z-Wave Scene Controller Debug Actuator Config Get received:
Z-Wave Scene Controller Debug Raw command: 01 09 00 04 00 12 03 2C 02 00 CD
Z-Wave Scene Controller Debug Node: 18
Z-Wave Scene Controller Debug Scene: 0
Here's a second debug, showing the sequence 1/on, 2/on, 3/on, 4/on, 1/off, 2/off, 3/off, 4/off
Feb 9, 2018 at 8:29:24 AM
Z-Wave Debug RCVD basicSetState: 01 09 00 04 08 12 03 20 01 FF 35
Z-Wave Debug . . basicSetState: node 018, endpoint None, value 255 (no node dispatch)
Z-Wave Debug RCVD basicSetState: 01 09 00 04 00 12 03 20 01 FF 3D
