Fibaro Universal Sensor Support
Forum rules
Sat Dec 02, 2017 12:53 pm
forestfield offline
Hi ,
I've just bought a Fibaro FGBS-001 Universal Sensor (https://www.amazon.co.uk/gp/product/B00 ... UTF8&psc=1), and it's not being fully recognised. Indigo sees it as an FGBS321, but doesn't add support for the 2 output relays. Also it should support up to 4 ds18b20 temperature sensors; I have 1 connected...
From the event log at sync...
2017-12-02 18:03:42.093 Z-Wave  Syncing - started for "083 - Binary Sensor (routing)"
2017-12-02 18:03:42.135 Z-Wave  Syncing - retrieved module neighbors list: - none -
2017-12-02 18:03:42.136 Z-Wave  Syncing - assigning return route to "083 - Binary Sensor (routing)"
2017-12-02 18:03:42.505 Z-Wave  Syncing - assigned return route
2017-12-02 18:03:43.117 Z-Wave  Syncing - retrieved manufacture and model names: Fibaro System - 010F, Universal Sensor (FGBS321) - 05011002
2017-12-02 18:03:43.405 Z-Wave  Syncing - retrieved protocol version 3.52, app version 2.01
2017-12-02 18:03:43.690 Z-Wave  Syncing - retrieved class hierarchy: Routing Slave : Binary Sensor : Binary Sensor (routing) (04 : 20 : 01, base 30)
2017-12-02 18:03:43.691 Z-Wave  Syncing - retrieved command classes: 20v1 60v2 85v1 86v1 70v1 8Ev1 30v1 72v1 7Av1
2017-12-02 18:03:43.691 Z-Wave  Syncing - retrieved encrypt commands: - none -
2017-12-02 18:03:43.692 Z-Wave  Syncing - retrieved capabilities: routing, beaming
2017-12-02 18:03:44.279 Z-Wave  Syncing - retrieved multi-endpoint types: 1:(20 : 01), 2:(20 : 01)
2017-12-02 18:03:44.280 Z-Wave  Syncing - retrieved multi-endpoint classes: 1:[30 9C], 2:[30 9C]
2017-12-02 18:03:44.854 Z-Wave  Syncing - retrieved group 1 associations: []
2017-12-02 18:03:45.141 Z-Wave  Syncing - retrieved group 2 associations: []
2017-12-02 18:03:45.427 Z-Wave  Syncing - retrieved group 3 associations: []
2017-12-02 18:03:45.715 Z-Wave  Syncing - added group 1 association to interface
2017-12-02 18:03:46.004 Z-Wave  Syncing - added group 2 association to interface
2017-12-02 18:03:46.291 Z-Wave  Syncing - added group 3 association to interface
2017-12-02 18:03:46.584 Z-Wave  Syncing - retrieved parameter 3 "Input 1 type" is 1 "Normally Closed"
2017-12-02 18:03:46.874 Z-Wave  Syncing - retrieved parameter 4 "Input 2 type" is 1 "Normally Closed"
2017-12-02 18:03:47.165 Z-Wave  Syncing - retrieved parameter 12 "Temperature sensitivity" is 8
2017-12-02 18:03:47.451 Z-Wave  Syncing - retrieved parameter 14 "Enable scene commands" is false
2017-12-02 18:03:47.987 Z-Wave  Syncing - created device "083 - Input 1"
2017-12-02 18:03:48.022 Z-Wave  Syncing - created device "083 - Input 2"
2017-12-02 18:03:48.038 Z-Wave  Syncing - complete
And dumping the device definition
 Z-Wave  Indigo Device "083 - Input 1" Z-Wave Properties:
Indigo Z-Wave Version: 2.0.111
Node ID: 83
Model: Universal Sensor (FGBS321)
Model ID: 05011002
Manufacturer: Fibaro System
Manufacturer ID: 010F
Protocol Version: 3.52
Application Version: 2.01
Model Definition Version: 8
Library Type: 3
Class Name: Binary Sensor (routing)
Class Hierarchy: 04 : 20 : 01
Command Class Base: 30
Command Versions: 20v1 60v2 85v1 86v1 70v1 8Ev1 30v1 72v1 7Av1
Multi-Endpoint Types: 1:(20 : 01), 2:(20 : 01)
Multi-Endpoint Classes: 1:[30 9C], 2:[30 9C]
Features: routing, beaming
Neighbors: - none -
Associations: 1:[1] 2:[1] 3:[1]
Config Values: 12:8 3:1 4:1 14:0
-- Paul --
Sat Dec 02, 2017 2:36 pm
Gusten offline
Re: Fibaro Universal Sensor Support
The relays only follows the inputs, they are not controllable.
Sun Dec 03, 2017 3:08 am
forestfield offline
Aha - basic misunderstanding! However the temperature monitoring was the bit I was really after...
Sun Dec 03, 2017 7:27 am
durosity offline
Did you add the temp sensor after pairing it with indigo? If so you’ll need to unpair then repair it. Same goes for if you ever add more or replace a module (I’ve got several of these hooked up and fully working)
Sun Dec 03, 2017 9:01 am
forestfield offline
Excellent - that did the job. I did resync, but hadn't thought about re-pairing.
Didn't help that one of pack of 5 ds18b20's I bought is bad - and that's the one I's connected. Luckily had a spare pi to test them all.
-- Paul --
Mon Dec 04, 2017 1:30 pm
durosity offline
Yeah testing the ds18b20 is a faf with the universal sensor having to pair and unpair. Still once they’re working they tend to keep working in my experience.. in the last 4 years I’ve only had one failure and I think I have about 30 sensors in various places.
