CliveS wrote:If you need any testing then I have a new (still in Amazon brown box) Dot 2 and have never installed the plugin so no previous data cached etc.
autolog wrote:CliveS wrote:If you need any testing then I have a new (still in Amazon brown box) Dot 2 and have never installed the plugin so no previous data cached etc.
According to an earlier post, the Echo Dot (Gen 2) works - It would be good to verify this.
Reloading plugin "Alexa-Hue Bridge 3.0.19"
Stopping plugin "Alexa-Hue Bridge 3.0.19" (pid 38905)
Alexa-Hue Bridge Alexa-Hue Bridge shutdown requested
Stopped plugin "Alexa-Hue Bridge 3.0.19"
Starting plugin "Alexa-Hue Bridge 3.0.19" (pid 39443)
Alexa-Hue Bridge Alexa-Hue Bridge initialising . . .
Alexa-Hue Bridge Plugin Host IP Address is discovered as: '192.168.100.150'
Alexa-Hue Bridge Alexa discovery request logging enabled
Alexa-Hue Bridge Warning Debugging enabled for Alexa-Hue Bridge: General, Server, Broadcaster, Responder, Method Trace
Started plugin "Alexa-Hue Bridge 3.0.19"
Alexa-Hue Bridge Alexa-Hue Bridge initialization complete
Alexa-Hue Bridge Alexa-Hue Bridge checking network access by attempting to access 'www.google.com'
Alexa-Hue Bridge Alexa-Hue Bridge network access check to www.google.com successfully completed.
Alexa-Hue Bridge Alexa-Hue Bridge checking for Plugin update
Alexa-Hue Bridge Checking for updates...
Alexa-Hue Bridge No updates are available
Alexa-Hue Bridge Alexa-Hue Bridge next update check scheduled for: Friday, 2017-Dec-01 at 22:33
30 Nov 2017, 22:37:38
SQL Logger creating table device_history_1500071656 for "Twigs"
30 Nov 2017, 22:38:20
Alexa-Hue Bridge 'Twigs' updated and now has one Alexa Device published
Alexa-Hue Bridge 'Twigs' has one Alexa Device published
Alexa-Hue Bridge Starting Hue Bridge 'Twigs' web server thread
Alexa-Hue Bridge Starting Hue Bridge 'Twigs' discovery thread as 'Auto Start Discovery' requested
Alexa-Hue Bridge Alexa-Hue Bridge 'Twigs' started: Host: 192.168.100.150 Port: 8178
SQL Logger adding column "onoffstate_ui" to table device_history_1500071656 ("Twigs")
Z-Wave received "Bathroom Temperature" sensor update to 16.7 °C
Alexa-Hue Bridge Alexa-Hue Bridge 'Twigs' responding to Alexa discovery [request id: 1] ...
Alexa-Hue Bridge + Publishing device 'Twigs' to Alexa
Alexa-Hue Bridge ... One device discovered by Alexa on Alexa-Hue Bridge 'Twigs'.
Alexa-Hue Bridge Alexa-Hue Bridge 'Twigs' responding to Alexa discovery [request id: 2] ...
30 Nov 2017, 22:38:59
Alexa-Hue Bridge Error StandardError detected in put_response for device 'Twigs'. Line '294' has error='not enough arguments for format string'
30 Nov 2017, 22:39:23
Alexa-Hue Bridge Set on state of Alexa device "Twigs" ["Living Room Twigs Switch"] to OFF
Z-Wave sent "Living Room Twigs Switch" off
Z-Wave received "Living Room Twigs Switch" power load to 0.0 W
30 Nov 2017, 22:39:39
Alexa-Hue Bridge Set on state of Alexa device "Twigs" ["Living Room Twigs Switch"] to ON
Z-Wave sent "Living Room Twigs Switch" on
30 Nov 2017, 22:40:14
devros wrote:Some more strange behavior to report. I was set up a 2nd dot(also 2nd gen) and at that point had both Dots plugged in and everything was working. At one point I had them both unplugged and then plugged in the original one I had done the setup with, and it couldn't connect to any of the devices. It was only when I plugged in the new one that it started working again. Very strange.
autolog wrote:Hi Clive,
Thanks for verifying that the Echo Dot (Gen 2) works.
The error message is a bug - the plugin was trying to output a message saying you were trying to dim a non-dimmable device (I hope that was what you were doing - I have replicated the error)..
I am doing some other minor coding tidy ups and then I will release a fix for this but as you discovered it doesn't stop the plugin working.
brick wrote:... Getting this error message when installing/discovering new devices - any ideas? ...
autolog wrote:brick wrote:... Getting this error message when installing/discovering new devices - any ideas? ...
... Are you running the latest version of the plugin? ...
CliveS wrote:autolog wrote:Hi Clive,
Yes I was trying to turn off the twigs from the Alexa app by sliding it fully left but it also gives the same response when I ask her to dim the twigs to 50% which is impossible on the LED twigs which can only do on/off, so I suspect the fix will be for me to not be stupid in the future
RAID5 wrote:I have just purchased a Dot Gen 2 and I can't get it to discover any devices.
I use Indigo 7.1.1 and version 3.0.20 of the Alexa Hue-Bridge plug-in.
I do use SONOS plugin but I have disabled it and used your command to check the port, it's unused before I start the Hue-Bridge plug-in.
I have enabled logging in the plug-in, but there is nothing there..
Should I use the Skill Hue from Philips Hue in Alexa or is there any other Skill I should use?
