High Sierra
High Sierra
Hi-
High Sierra removes the telnet binary which seems to break the plugin. I used Brew to restore the binary and that seems to have corrected the problem. My own plugins use the python telnetlib libraries and they seem to be working without the telnet binary.
Just FYI
Mike
Just FYI
Mike
Re: High Sierra
I spoke too soon. I am getting these errors:
Nov 17, 2017 at 9:40:28 AM
Onkyo Network Remote Plugin Error Error during background processing
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 262, in concurrentCommandProcessingThread
responseText = RPFrameworkUtils.to_unicode(self.readIfAvailable(ipConnection, lineEndingToken, commandResponseTimeout))
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/onkyoNetworkRemoteDevice.py", line 179, in readIfAvailable
return self.readLine(connection, lineEndingToken, commandResponseTimeout)
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/onkyoNetworkRemoteDevice.py", line 164, in readLine
header = eISCP.eISCPPacket.parse_header(header_bytes)
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/eISCP.py", line 198, in parse_header
assert len(bytes) == 16
AssertionError
Re: High Sierra
RogueProeliator,
I'm wondering if you wouldn't mind taking a quick look at this for me. I booted up a VM with Indigo and confirmed that your plugin works fine with my Onkyo configured on OS X El Cap. In High Sierra, several functions cause the plugin to fail according the debug logs that comes out of the plugin. Zone 2 state changes, in particular, seem to be causing problems.
I've attached a list of my logs during a restart of the plugin. Both Indigo instances have the same Onkyo configured.
Hopefully I can help fix this myself but I'm so far at a loss as to what is happening. Appreciate if you can help.
Mike
Mike
- El_Cap_log.txt
- (93.9 KiB) Downloaded 307 times
- HS_Log.txt
- (59.44 KiB) Downloaded 320 times
- RogueProeliator
Re: High Sierra
Hey Mike:I'm wondering if you wouldn't mind taking a quick look at this for me. I booted up a VM with Indigo and confirmed that your plugin works fine with my Onkyo configured on OS X El Cap. In High Sierra, several functions cause the plugin to fail according the debug logs that comes out of the plugin. Zone 2 state changes, in particular, seem to be causing problems.
I just returned from a vacation visiting family in the sticks for Thanksgiving... I've added this to a growing list of Indigo-related things to investigate this weekend. Hope to have some sleep and maybe a bit of time tomorrow; if not then this weekend for sure.
Adam
Re: High Sierra
Thanks. I available to help. Would love to get this solved.
- RogueProeliator
Re: High Sierra
This error seems to be buried deeply within the Onkyo library that the plugin uses to parse and encode the messages to/from the receiver... the packet for the header of the communication message structure is less than the expected size (the specific error message is an assertion due to the header not being 16 bytes... but the caller is requesting only (up to) the first 16 bytes, so it must be less than 16 bytes.
I'm wondering if this has something to do with the handling of sockets - not waiting for the full input or the like. A couple of things to help narrow this down:
Adam
- Does the error happen at every status update check?
- Is it always in, roughly, the same part of the status update -- you mentioned you thought it may be Zone 2 related, is that because the error is always within those status checks?
- Can you turn the status updates to very infrequent and try a few manual sends to narrow down the error? Go to Send Arbitrary Command from the Plugin menu and could try any of the Zone 2 commands; the values to send for Zone 2 would be: ZPWQSTN or SLZQSTN or ZVLQSTN
Adam
Re: High Sierra
Adam,
Frist off, I'm a bit embarrassed. I never wanted to upgrade to HS, I was kind-of forced by some updates to other software that I waned to be compatible with, namely my remote control (Simple Control, which is a iOS app for AV Control). At first, I was using my Simple Control remote to test what was and was not working in your plugin. However most of these are embedded in activities that are essentially macros with multiple commands to my system. To respond to your note, I fired up the Onkyo remote app to test individual commands, and found to my amazement that everything was working fine.
As it turns out, this error has nothing to do with HS, but rather SimpleControl is sending some kind of commands to the Onkyo that the plugin cannot handle. I suppose your plugin is getting these commands via the status mechanism?
Now that we know this, is there something that we can do, to handle the commands more gracefully?
Thanks again for helping getting to the bottom of this.
Re: High Sierra
Okay. This is bizarre. I booted up my OS X 10.12.6 again, and tested SimpleControl interacting with the Onkyo, and your plugin handled the updates just fine. I cannot figure out which individual updates are being received that are being processed differently only on my HS box. What I know for sure is that your plugin works fine when Simple Control is not open on any of my iDevices. I can't seem to do anything in the native Onkyo controller app that replicates what is happening in Simple Control, but this could be just a command that I'm not aware of. Since SimpleControl is interacting with the Onkyo directly, and your plugin is getting feedback from the Onkyo, I'm back to my original hypothesis that there is some difference in interpretation between El Cap and High Sierra.
Test 2 below shows some bizarre characters in the debug log. Does that look right to you?
Side by side test: Launching Simple Control after restarting the plugin. First code block is HS (Crash). Second is El Cap (handles fine).
Side by side test 2: Restarting the plugin while SimpleControl is already open:
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('net-usb-jacket-art', '2-http://10.66.0.51/album_art.cgi')
Onkyo Network Remote Plugin Threaddebug Received w/o Command: (('master-volume', 'volume'), '3C')
Onkyo Network Remote Plugin Threaddebug Found response match: deviceMasterVolumeQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "masterVolumeLevel" to "60"
Onkyo Network Remote Plugin Debug Effect execution: Calling function updateVirtualMasterVolume
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/onkyoNetworkRemoteDevice.py", line 180, in readIfAvailable
AssertionError
Onkyo Network Remote Plugin Debug Closing connection to device
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('input-selector', ('dvd', 'bd', 'dvd'))
Onkyo Network Remote Plugin Threaddebug Found response match: deviceInputSelectorQuery
Onkyo Network Remote Plugin Debug Effect execution: Calling function inputSelectorQueryReceived
Onkyo Network Remote Plugin Debug Updating current input number/label: 10 / DVD, BD/DVD
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('listening-mode', 'all-ch-stereo')
Onkyo Network Remote Plugin Threaddebug Found response match: listeningModeQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "listeningMode" to "all-ch-stereo"
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('audio-muting', 'off')
Onkyo Network Remote Plugin Threaddebug Found response match: deviceIsMutedQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "isMuted" to "False"
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('system-power', 'on')
Onkyo Network Remote Plugin Threaddebug Found response match: devicePowerQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "isPoweredOn" to "True" with UIValue "On"
Reloading plugin "Onkyo Network Remote Plugin 2.1.1"
Stopping plugin "Onkyo Network Remote Plugin 2.1.1" (pid 82668)
Onkyo Network Remote Plugin Debug Entering deviceStopComm for House AV - Main Area Onkyo; ID=1156835359
Onkyo Network Remote Plugin Debug Initiating shutdown of communications with House AV - Main Area Onkyo
Onkyo Network Remote Plugin Debug Shutdown of communications with House AV - Main Area Onkyo complete
Onkyo Network Remote Plugin Debug Exiting deviceStopComm for House AV - Main Area Onkyo
Stopped plugin "Onkyo Network Remote Plugin 2.1.1"
Starting plugin "Onkyo Network Remote Plugin 2.1.1" (pid 83185)
Onkyo Network Remote Plugin Threaddebug Initializing RPFrameworkPlugin
Onkyo Network Remote Plugin Debug Beginning processing of RPFrameworkConfig.xml file
Onkyo Network Remote Plugin Threaddebug Found plugin setting: pluginUpdateURL=http://forums.indigodomo.com/viewtopic.php?f=146&t=12325
Onkyo Network Remote Plugin Threaddebug Found device mapping; id: onkyoReceiverNetworkRemoteDevice to class: OnkyoReceiverNetworkRemoteDevice
Onkyo Network Remote Plugin Threaddebug Found device mapping; id: onkyoVolumeController to class: OnkyoVirtualVolumeController
Onkyo Network Remote Plugin Threaddebug Created device parameter for managed device "onkyoReceiverNetworkRemoteDevice": ipAddress
Onkyo Network Remote Plugin Threaddebug Created device parameter for managed device "onkyoReceiverNetworkRemoteDevice": portNumber
Onkyo Network Remote Plugin Threaddebug Created device parameter for managed device "onkyoReceiverNetworkRemoteDevice": updateInterval
Onkyo Network Remote Plugin Threaddebug Created device parameter for managed device "onkyoReceiverNetworkRemoteDevice": deviceZonesConnected
Onkyo Network Remote Plugin Threaddebug Created device parameter for managed device "onkyoReceiverNetworkRemoteDevice": deviceInputsConnected
Onkyo Network Remote Plugin Threaddebug Found device setting: childDeviceDictionaryKeyFormat=%dp:zoneNumber%
Onkyo Network Remote Plugin Threaddebug Found device setting: commandReadTimeout=0.1
Onkyo Network Remote Plugin Threaddebug Found device setting: deviceAddressFormat=%ap:ipAddress%:%ap:portNumber%
Onkyo Network Remote Plugin Threaddebug Found device setting: deviceIsChildDevice=False
Onkyo Network Remote Plugin Threaddebug Found device setting: reconnectAttemptLimit=99
Onkyo Network Remote Plugin Threaddebug Found device setting: reconnectAttemptDelay=30
Onkyo Network Remote Plugin Threaddebug Found device setting: socketConnectionTimeout=3
Onkyo Network Remote Plugin Threaddebug Found device setting: telnetConnectionDeviceStateName=connectionState
Onkyo Network Remote Plugin Threaddebug Found device setting: telnetConnectionDeviceStateBoolean=isConnected
Onkyo Network Remote Plugin Threaddebug Found device setting: updateStatusPollerActionId=updateReceiverStatusFull
Onkyo Network Remote Plugin Threaddebug Found device setting: updateStatusPollerIntervalProperty=updateInterval
Onkyo Network Remote Plugin Threaddebug Found device response: devicePowerQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: isPoweredOn; ValueFormat=re.match("\('system\-power',\s{0,1}'(?P<value>(on)|(off)|(standby))'\)", "%cp:response%").groupdict().get("value") == "on"; ValueFormatEx="On" if re.match("\('system\-power',\s{0,1}'(?P<value>(on)|(off)|(standby))'\)", "%cp:response%").groupdict().get("value") == "on" else "Standby"; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=eventCallback; Param: updateVirtualMasterVolume; ValueFormat=; ValueFormatEx=; Eval=False; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: zonePowerQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: zone2PoweredOn; ValueFormat=re.match("\('power',\s{0,1}'(?P<value>(on)|(off)|(standby))'\)", "%cp:response%").groupdict().get("value") == "on"; ValueFormatEx="On" if re.match("\('power',\s{0,1}'(?P<value>(on)|(off)|(standby))'\)", "%cp:response%").groupdict().get("value") == "on" else "Standby"; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: deviceSleepTimerQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: sleepTimer; ValueFormat=int(re.match("\('sleep\-set',\s{0,1}'(?P<value>[A-F\d]+)'\)", "%cp:response%").groupdict().get("value"),16); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: deviceMasterVolumeQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: masterVolumeLevel; ValueFormat=int(re.match("^\(\('master\-volume',\s*\'volume\'\),\s*\'{0,1}(?P<value>[A-F\d]+)\'{0,1}\)", "%cp:response%").groupdict().get("value"),16); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: deviceZoneVolumeQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: zone2VolumeLevel; ValueFormat=int(re.match("^\('volume',\s{0,1}'(?P<value>[A-F\d]+)'\)", "%cp:response%").groupdict().get("value"),16); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=eventCallback; Param: updateVirtualZone2Volume; ValueFormat=; ValueFormatEx=; Eval=False; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: deviceZoneVolumeQueryNA
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: zone2VolumeLevel; ValueFormat=0; ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: deviceIsMutedQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: isMuted; ValueFormat=re.match("\('audio\-muting',\s{0,1}'(?P<value>(on)|(off))'\)", "%cp:response%").groupdict().get("value") == "on"; ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: deviceHDMIAudioOutQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: hdmiAudioOut; ValueFormat=re.match("\('hdmi\-audio\-out',\s{0,1}'(?P<value>(on)|(off))'\)", "%cp:response%").groupdict().get("value") != "off"; ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: listeningModeQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: listeningMode; ValueFormat=re.match("^\('listening\-mode',\s{0,1}(?P<value>('|\().+('|\)))\)$", "%cp:response%").groupdict().get("value").replace("'", "").replace("(", "").replace(")", ""); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: deviceInputSelectorQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=eventCallback; Param: inputSelectorQueryReceived; ValueFormat=; ValueFormatEx=; Eval=False; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: zone2InputSelectorQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=eventCallback; Param: zone2SelectorQueryReceived; ValueFormat=; ValueFormatEx=; Eval=False; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: tunerFrequencyQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: tunerFrequency; ValueFormat=re.match("\('tuning',\s{0,1}'(?P<value>[\d\.]+)'\)", "%cp:response%").groupdict().get("value"); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: currentVideoOutResQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: videoOutputResolution; ValueFormat=re.match("^\('monitor\-out\-resolution',\s{0,1}(?P<value>('|\().+('|\)))\)$", "%cp:response%").groupdict().get("value").replace("'", ""); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: videoWideScreenModeQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: videoWideScreenMode; ValueFormat=re.match("\('video\-wide\-mode',\s{0,1}'(?P<value>[a-zA-Z\d\-]*)'\)", "%cp:response%").groupdict().get("value"); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: speakerAStatusQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: speakerAPower; ValueFormat=re.match("\('speaker\-a',\s{0,1}'(?P<value>(on)|(off)|(N/A))'\)", "%cp:response%").groupdict().get("value") == "on"; ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: speakerBStatusQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: speakerBPower; ValueFormat=re.match("\('speaker\-b',\s{0,1}'(?P<value>(on)|(off)|(N/A))'\)", "%cp:response%").groupdict().get("value") == "on"; ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: streamingArtistQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: networkPlayArtist; ValueFormat=re.match("\('net\-usb\-artist\-name\-info',\s{0,1}'(?P<value>.+)'\)", "%cp:response%").groupdict().get("value"); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: streamingAlbumQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: networkPlayAlbum; ValueFormat=re.match("\('net\-usb\-album\-name\-info',\s{0,1}'(?P<value>.+)'\)", "%cp:response%").groupdict().get("value"); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: streamingTitleQuery
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: networkPlayTitle; ValueFormat=re.match("\('net\-usb\-title\-name',\s{0,1}'(?P<value>.+)'\)", "%cp:response%").groupdict().get("value"); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Found device response: streamingTitleStatus
Onkyo Network Remote Plugin Threaddebug Found response effect: Type=updateDeviceState; Param: networkPlayStatus; ValueFormat=re.match("\('net\-usb\-play\-status',\s{0,1}'(?P<value>.{3})'\)", "%cp:response%").groupdict().get("value"); ValueFormatEx=; Eval=True; Condition=
Onkyo Network Remote Plugin Threaddebug Created device parameter for managed device "onkyoVolumeController": sourceReceiver
Onkyo Network Remote Plugin Threaddebug Created device parameter for managed device "onkyoVolumeController": zoneNumber
Onkyo Network Remote Plugin Threaddebug Created device parameter for managed device "onkyoVolumeController": maxVolume
Onkyo Network Remote Plugin Threaddebug Found device setting: deviceAddressFormat=Zone: %ap:zoneNumber%
Onkyo Network Remote Plugin Threaddebug Found device setting: deviceIsChildDevice=True
Onkyo Network Remote Plugin Threaddebug Found device setting: deviceParentIdProperty=sourceReceiver
Onkyo Network Remote Plugin Threaddebug Found managed action: updateReceiverStatusFull
Onkyo Network Remote Plugin Threaddebug Found managed action: setPowerStatus
Onkyo Network Remote Plugin Threaddebug Processing 1 params for action
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setPowerStatus": powerCommand
Onkyo Network Remote Plugin Threaddebug Found managed action: setZonePowerStatus
Onkyo Network Remote Plugin Threaddebug Processing 2 params for action
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setZonePowerStatus": zone
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setZonePowerStatus": powerCommand
Onkyo Network Remote Plugin Threaddebug Found managed action: setSleepTime
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setSleepTime": sleepTime
Onkyo Network Remote Plugin Threaddebug Found managed action: adjustVolumeLevel
Onkyo Network Remote Plugin Threaddebug Processing 3 params for action
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "adjustVolumeLevel": zone
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "adjustVolumeLevel": adjustmentType
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "adjustVolumeLevel": repeatCount
Onkyo Network Remote Plugin Threaddebug Found managed action: setVolumeLevel
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setVolumeLevel": zone
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setVolumeLevel": volumeLevel
Onkyo Network Remote Plugin Threaddebug Found managed action: setAudioMuting
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setAudioMuting": zone
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setAudioMuting": muteCommand
Onkyo Network Remote Plugin Threaddebug Found managed action: setHDMIAudioPassthrough
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setHDMIAudioPassthrough": hdmiAudioOutCmd
Onkyo Network Remote Plugin Threaddebug Found managed action: setListeningMode
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setListeningMode": listeningMode
Onkyo Network Remote Plugin Threaddebug Found managed action: setCurrentInput
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setCurrentInput": zone
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setCurrentInput": inputNumber
Onkyo Network Remote Plugin Threaddebug Found managed action: tuneToStation
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "tuneToStation": zone
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "tuneToStation": station
Onkyo Network Remote Plugin Threaddebug Found managed action: setVideoOutResolution
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setVideoOutResolution": videoResolution
Onkyo Network Remote Plugin Threaddebug Found managed action: setVideoOutWideScreenMode
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setVideoOutWideScreenMode": videoMode
Onkyo Network Remote Plugin Threaddebug Found managed action: setVideoPictureMode
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setVideoPictureMode": videoMode
Onkyo Network Remote Plugin Threaddebug Found managed action: setSpeakerOnOff
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setSpeakerOnOff": speakerSet
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setSpeakerOnOff": speakerCommand
Onkyo Network Remote Plugin Threaddebug Found managed action: setSpeakerTone
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setSpeakerTone": speakerTarget
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setSpeakerTone": toneType
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setSpeakerTone": newValue
Onkyo Network Remote Plugin Threaddebug Found managed action: setAuxTriggerOnOff
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setAuxTriggerOnOff": triggerId
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "setAuxTriggerOnOff": powerState
Onkyo Network Remote Plugin Threaddebug Found managed action: TurnOn
Onkyo Network Remote Plugin Threaddebug Found managed action: TurnOff
Onkyo Network Remote Plugin Threaddebug Found managed action: Toggle
Onkyo Network Remote Plugin Threaddebug Found managed action: SetBrightness
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "SetBrightness": actionValue
Onkyo Network Remote Plugin Threaddebug Found managed action: StatusRequest
Onkyo Network Remote Plugin Threaddebug Found managed action: SendArbitraryCommand
Onkyo Network Remote Plugin Threaddebug Created parameter for managed action "SendArbitraryCommand": commandToSend
Onkyo Network Remote Plugin Debug Successfully completed processing of RPFrameworkConfig.xml file
Started plugin "Onkyo Network Remote Plugin 2.1.1"
Onkyo Network Remote Plugin Threaddebug Returning default GUIConfigValue for plugin:databaseConnectionEnabled
Onkyo Network Remote Plugin Threaddebug Database access enabled:
Onkyo Network Remote Plugin Threaddebug Database access has been disabled, skipping connection
Onkyo Network Remote Plugin Debug Entering deviceStartComm for House AV - Main Area Onkyo; ID=1156835359
Onkyo Network Remote Plugin Threaddebug Read device state config... isConnected: "isConnected"; connectionState: "connectionState"
Onkyo Network Remote Plugin Debug Establishing connection to 10.66.0.51
Onkyo Network Remote Plugin Debug Exiting deviceStartComm for House AV - Main Area Onkyo
Onkyo Network Remote Plugin Threaddebug Returning default GUIConfigValue for plugin:pluginCommandQueueIdleSleep
Onkyo Network Remote Plugin Debug Version check initiated
Onkyo Network Remote Plugin Debug Connection established
Onkyo Network Remote Plugin Checking for updates...
Onkyo Network Remote Plugin Threaddebug Returning default GUIConfigValue for onkyoReceiverNetworkRemoteDevice:telnetConnectionEOLString
Onkyo Network Remote Plugin Debug Plugin version detected: 2.1.1
Onkyo Network Remote Plugin Threaddebug Returning default GUIConfigValue for onkyoReceiverNetworkRemoteDevice:telnetConnectionStringEncoding
Onkyo Network Remote Plugin Debug Current version is: 2.1.1
Onkyo Network Remote Plugin Threaddebug Returning default GUIConfigValue for onkyoReceiverNetworkRemoteDevice:telnetConnectionRequiresLoginProperty
Onkyo Network Remote Plugin Debug Getting latest release from RogueProeliator/IndigoPlugins-Onkyo-Receiver-Network-Remote...
Onkyo Network Remote Plugin Threaddebug Returning default GUIConfigValue for onkyoReceiverNetworkRemoteDevice:emptyQueueReducedWaitCycles
Onkyo Network Remote Plugin Debug GET /repos/RogueProeliator/IndigoPlugins-Onkyo-Receiver-Network-Remote/releases/latest
Onkyo Network Remote Plugin Threaddebug Command queue has 1 command(s) waiting
Onkyo Network Remote Plugin Threaddebug Create connection command de-queued
Onkyo Network Remote Plugin Threaddebug Received: ('net-usb-jacket-art', '2-http://10.66.0.51/album_art.cgi')
Onkyo Network Remote Plugin Debug Executing full status update request...
Onkyo Network Remote Plugin Threaddebug Command queue has 22 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: PWRQSTN
Onkyo Network Remote Plugin Threaddebug Send command completed.
Onkyo Network Remote Plugin Debug HTTP 200 OK
Onkyo Network Remote Plugin Debug Latest release is: 2.1.1
Onkyo Network Remote Plugin No updates are available
Onkyo Network Remote Plugin Threaddebug Received: ('system-power', 'on')
Onkyo Network Remote Plugin Threaddebug Command queue has 21 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: MVLQSTN
Onkyo Network Remote Plugin Threaddebug Received: (('master-volume', 'volume'), '3C')
Onkyo Network Remote Plugin Threaddebug Command queue has 20 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: AMTQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('audio-muting', 'off')
Onkyo Network Remote Plugin Threaddebug Command queue has 19 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: HAOQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('hdmi-audio-out', 'off')
Onkyo Network Remote Plugin Threaddebug Found response match: deviceHDMIAudioOutQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "hdmiAudioOut" to "False"
Onkyo Network Remote Plugin Threaddebug Command queue has 18 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLIQSTN
File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/Onkyo Network Remote.indigoPlugin/Contents/Server Plugin/RPFramework/RPFrameworkTelnetDevice.py", line 242, in concurrentCommandProcessingThread
responseText = RPFrameworkUtils.to_unicode(self.readLine(ipConnection, lineEndingToken, commandResponseTimeout))
AssertionError
Nov 26, 2017, 5:30:03 PM
Onkyo Network Remote Plugin Threaddebug Received: ('input-selector', ('dvd', 'bd', 'dvd'))
Onkyo Network Remote Plugin Threaddebug Command queue has 17 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: SPAQSTN
Onkyo Network Remote Plugin Threaddebug Command queue has 16 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: SPBQSTN
Onkyo Network Remote Plugin Threaddebug Command queue has 15 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLPQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('sleep-set', 'time-off')
Onkyo Network Remote Plugin Threaddebug Command queue has 14 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: HDOQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('hdmi-output-selector', ('yes', 'out'))
Onkyo Network Remote Plugin Threaddebug Command queue has 13 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: RESQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('monitor-out-resolution', 'through')
Onkyo Network Remote Plugin Threaddebug Found response match: currentVideoOutResQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "videoOutputResolution" to "through"
Onkyo Network Remote Plugin Threaddebug Command queue has 12 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: VWMQSTN
Onkyo Network Remote Plugin Threaddebug Command queue has 11 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: VPMQSTN
Onkyo Network Remote Plugin Threaddebug Command queue has 10 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: LMDQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('listening-mode', 'all-ch-stereo')
Onkyo Network Remote Plugin Threaddebug Command queue has 9 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLAQSTN
Onkyo Network Remote Plugin Threaddebug Command queue has 8 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: TUNQSTN
Onkyo Network Remote Plugin Threaddebug Command queue has 7 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: NATQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('audio-selector', 'hdmi')
Onkyo Network Remote Plugin Threaddebug Command queue has 6 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: NALQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('net-usb-artist-name-info', ' ')
Onkyo Network Remote Plugin Threaddebug Found response match: streamingArtistQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayArtist" to " "
Onkyo Network Remote Plugin Threaddebug Command queue has 5 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: NTIQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('tuning', '08750')
Onkyo Network Remote Plugin Threaddebug Found response match: tunerFrequencyQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "tunerFrequency" to "08750"
Onkyo Network Remote Plugin Threaddebug Command queue has 4 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: NSTQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('net-usb-album-name-info', ' ')
Onkyo Network Remote Plugin Threaddebug Found response match: streamingAlbumQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayAlbum" to " "
Onkyo Network Remote Plugin Threaddebug Command queue has 3 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: ZPWQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('net-usb-title-name', ' ')
Onkyo Network Remote Plugin Threaddebug Found response match: streamingTitleQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "networkPlayTitle" to " "
Onkyo Network Remote Plugin Threaddebug Command queue has 2 command(s) waiting
Onkyo Network Remote Plugin Debug Sending eISCP Command: SLZQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('power', 'on')
Onkyo Network Remote Plugin Threaddebug Found response match: zonePowerQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "zone2PoweredOn" to "True" with UIValue "On"
Onkyo Network Remote Plugin Debug Sending eISCP Command: ZVLQSTN
Onkyo Network Remote Plugin Threaddebug Received: ('selector', ('dvd', 'bd', 'dvd'))
Onkyo Network Remote Plugin Threaddebug Found response match: zone2InputSelectorQuery
Onkyo Network Remote Plugin Debug Effect execution: Calling function zone2SelectorQueryReceived
Onkyo Network Remote Plugin Debug Updating zone 2 input number/label: 10 / DVD, BD/DVD
Onkyo Network Remote Plugin Threaddebug Received w/o Command: ('volume', '2D')
Onkyo Network Remote Plugin Threaddebug Found response match: deviceZoneVolumeQuery
Onkyo Network Remote Plugin Debug Effect execution: Update state "zone2VolumeLevel" to "45"
Onkyo Network Remote Plugin Debug Effect execution: Calling function updateVirtualZone2Volume
- RogueProeliator
Re: High Sierra
Okay, so just to summarize to be sure that I have my head wrapped around this:
This is a shot in the dark, but I am wondering if SimpleControl is sending some type of character or string encoding that gets passed along to the plugin and whose handling changed with High Sierra. I don't think it is this exact scenario, but something like Unicode registering as 2 chars in one and converted to a single ASCII char in another, throwing off the length. I think our best bet is to log the incoming message if we can. If you are up for a little Python modification (if you aren't, let me know but I've seen that you have authored plugins so I am assuming you are fine with it)...
Add the second line to onkyoNetworkRemoteDevice.py, approximately line 163:
I THINK that will work, though I don't really know for sure if Python will allow that direct conversion... if not, we can break up the header with:
... and print those components that are unpacked.
Adam
- The plugin on its own (no other applications open/involved) works fine
- The plugin works fine in conjunction with the Onkyo mobile application as far as you can tell
- The plugin works fine when used in conjunction with SimpleControl pre-High Sierra
- The plugin fails when used in conjunction with SimpleControl on High Sierra
header_bytes = connection.recv(16)
self.hostPlugin.logger.debug(u'EISCP Header: [' + RPFramework.RPFrameworkUtils.to_unicode(header_bytes) + ']')Code: Select all
magic, header_size, data_size, version, reserved = struct.unpack('! 4s I I b 3s', bytes)Adam
Re: High Sierra
Thanks Adam,
Yes I'm fine with hacking your plugin
. I had already tried adding a simple try/catch to see if ignoring the bad commands led to a better result. This hasn't worked.
When I add the logging line you recommended (the first one worked), the Indigo log shows an empty set for headers for the commands that fail. Interestingly, I went to your plugin log folder to look at the log without other chatter from my network, and found strange characters for some of the commands, others had a empty set.
EDIT: If you would like me to add your second line of code, I might need further instructions. My Python is pretty basic.
Full log file is attached (compressed), Sublime text doesn't seem to know what to do with these characters.
Full log: https://www.dropbox.com/s/rlnn0fu0k7cx4 ... g.zip?dl=0
Also, to make it easier to quickly review, I took a screen grab.
Mike
Mike
- ScreenShot.jpg (248 KiB) Viewed 6028 times
- RogueProeliator
Re: High Sierra
Hey Mike:
I posted a new version of the plugin if you wouldn't mind taking a peek -- this won't have your debug code in there, so we may need to restore that -- but it does update one thing that COULD be relevant. The library that the plugin uses does not support some variable-length commands; I am not sure of the implication as I haven't researched what they are, BUT the library had an update that seemed to allow it to read or at least parse incoming variable-length commands. No idea if this is any relation, but I updated that portion of the library in case maybe SimpleControls was using one and the plugin was having issues parsing it when the Onkyo passed along a status.
If this new version still fails, any way you could get that same capture/screen shot from the last post in a pre-High Sierra mode to compare and contrast those non-printing characters. I suspect NUL is simply a NULL / empty byte but there are others in there too that I have no guess at all.
Adam
Adam
Re: High Sierra
Thanks for continuing to work on this.
The updated plugin did not fix the issue. I think I'm closer to getting an exact comparison between the logs of the commands that are causing the crash. I'm hoping these help you more.
It seems the very first command that the plugin receives from SimpleControl immediately causes the crash. Hopefully the pattern is the same in that fixing one will fix them all, but who knows.
I'm fairly sure that the EISCP header for the command below the comment in my screenshot is the command that comes up as an empty set on the 10.13 machine and crashes. It contains a ")" character in the header, which stood out to me.
Let me know what you think.
- 10.12 Log.jpg (415.25 KiB) Viewed 5904 times
- 10.13 Log.jpg (415.06 KiB) Viewed 5904 times
Re: High Sierra
Adam,
I've resolved my problems. There doesn't seem to be a a High Sierra incompatibility. Instead, HS seems to behave differently with the Hub for SimpleControl. It seems your plugin and it both subscribe to UDP traffic on the same port. This crashes your plugin and I'm not sure what effect it has on the hub software. I've chosen to favor your plugin and move the hub to another machine.
In testing your most recent version, I noticed that my Zone2 volume was not updating the state in your plugin. Controlling Zone 2 volume is the main use case for how I use your plugin. I downgraded to the previous version and everything is working fine.
Thanks again for your help and I apologize that the problem was never with your code.
Mike
Mike
