MarcoGT wrote:Is the rain gauge working out of box? I mean, can I integrate into Indigo?
Marco
Yes it works and can be integrated via the plugin.
Marco
MarcoGT wrote:Is the rain gauge working out of box? I mean, can I integrate into Indigo?....
13 Nov 2017, 18:10:10
Netatmo Plugin Netatmo device configuration changed. Polling Netatmo's web server for an update
Netatmo Plugin Error Error in plugin execution UiClosed2:
File "plugin.py", line 227, in closedDeviceConfigUi
File "plugin.py", line 107, in readNetatmo
AttributeError: 'NoneType' object has no attribute 'items'
13 Nov 2017, 18:10:47
Reloading plugin "Netatmo Plugin 0.6.0"
Stopping plugin "Netatmo Plugin 0.6.0" (pid 84866)
Netatmo Plugin Stopping Netatmo plugin
Stopped plugin "Netatmo Plugin 0.6.0"
Starting plugin "Netatmo Plugin 0.6.0" (pid 85122)
Netatmo Plugin Log level preferences are set to "Normal".
Started plugin "Netatmo Plugin 0.6.0"
Netatmo Plugin Your plugin version, v0.6.0, is current.
Netatmo Plugin Error Plugin stopping. Reason = 'NoneType' object has no attribute 'items'
Netatmo Plugin Stopping Netatmo device read loop
Netatmo Plugin Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
MartinG wrote:It sounds like a device configuration error. I suggest you delete all your Netatmo devices and then restart with just the indoor module, making sure you have the Netatmo Station Name and Module Name entered exactly as they are set in the Netatmo web site. Note, the Indigo Device name is just a label and does not have to be the same as the Module name.My turn to suffer the plugin problems posted above. I do have a little debug info to add.
... ...On configuring the plugin for the first time, having read (and I think implemented, correctly, all the guidance above on app names etc), I get this:...
mlooss wrote:...Below are the errors I get, maybe some can figure out what is going on here...
Netatmo Plugin Debug Entered: Funct readNetatmo
Netatmo Plugin Debug Entered: ClientAuth init
Netatmo Plugin Error Plugin stopping. Reason = HTTP Error 400:
berkinet wrote:mlooss wrote:...Below are the errors I get, maybe some can figure out what is going on here...
The 400 Error is sent by Netatmo and indicates they see a problem with your request, Probably your credentials... account, password, etc. Set the debugging to a higher level to get more details on the request.
mlooss wrote:...this log excerpt was with the highest debug level setting....
berkinet wrote:mlooss wrote:...this log excerpt was with the highest debug level setting....
I have uploaded a new version of the plugin that will give a little more information about the request sent to Netatmo. It is available at:
https://drive.google.com/open?id=1d-RsH ... Kr4pp51Avr
NOTE to other users: Unless you are having connection problems, do not download this version. It has no functional changes.
mlooss wrote:...I got the plug-in working, without the new test release, at least somewhat. ...Should I still install this release from you?...
Enabling plugin "Netatmo Plugin 0.6.3"
Starting plugin "Netatmo Plugin 0.6.3" (pid 44515)
Netatmo Plugin Error Error in plugin execution InitializeMain:
File "plugin.py", line 15, in <module>
File "/Library/Application Support/Perceptive Automation/Indigo 6/Plugins/Netatmo.indigoPlugin/Contents/Server Plugin/berkinet.py", line 5, in <module>
ImportError: No module named requests
MarcoGT wrote:Your Mac is missing the Python requests module. I believe this is included in Indigo 7. If you do not have it, you may need to add it to your MacOS Python installation. Though, I have never had any other reports that it was not available.Is the plugin working with Indigo 6?
I get following errors:......
- Code: Select all
MarcoGT wrote:Okay, upgraded to I7 and plugin is loaded. I added the base module but I get HTTP error 400. I have only added the username and password of Netatmo login. No client/secret key. The base module name is the name of the internal module which I find on the Netatmo app?
Users browsing this forum: No registered users and 27 guests
