Device sort/status display is better, but odd still
Wed Nov 15, 2017 10:06 am
So sorting seems to be working better, but now I see this.
Down is green? Is that intentional? And I notice that some but not all expired devices are green. Looks like maybe recently expired are green?
Screen Shot 2017-11-15 at 11.03.03 AM.png (222.71 KiB) Viewed 962 times
SmartThings refugee, so happy to be on Indigo. 10.12.6 on an i5 MBP w/Harmony Hub, Hue, DomoPad, Dynamic URL, Device Extensions, HomeKit Bridge, MatplotLib, Plex, uniFAP, Wunderground, Nanoleaf, LED Simple Effects, Airfoil Pro, Grafana.
Wed Nov 15, 2017 12:03 pm
Re: Device sort/status display is better, but odd still
That’s either a bug or the device is “ignored”
I could flip the expired /up/down with the date stamp it might look better. But it is aligned center if it would be left or right it would look better.
Ps you can not sort this column in indigo.
Thu Nov 16, 2017 10:05 am
Different Computers : could you try version ...71. that should fix any "misalignment" of the status.
Mon Nov 20, 2017 8:50 am
Hey, just upgraded to 7.9.72
Still see this:
Screen Shot 2017-11-20 at 9.47.35 AM.png (99.32 KiB) Viewed 847 times
Mon Nov 20, 2017 10:23 am
mine work fine..
what kind of devices are these: in device edit what is used for up/down status determination wifi/switch/dhcp?
also it it is forced to sync when the plugin reloads. It does not do this?
Mon Nov 20, 2017 11:36 am
Here's a larger screenshot. Labels on the devices should explain what they are for the most part. But there's not much commonality about what shows Down but green. Also I can confirm many of these devices are actually up!
For example the iPad mini is right next to me and I can see it getting updated images from one of the cameras on my LAN.
Screen Shot 2017-11-20 at 12.33.46 PM.png (297.3 KiB) Viewed 825 times
Mon Nov 20, 2017 11:54 am
could you post the device edit screen and the device states screen for that iPad?
Mon Nov 20, 2017 1:34 pm
Afraid I don't know what the "device states" screen is. I'm 99% certain this device uses all default values. Only devices I've messed with are phones.
Mon Nov 20, 2017 3:10 pm
click on device, move up the pane that shows the states
Screen Shot 2017-11-20 at 15.10.10.png (71.93 KiB) Viewed 794 times
Mon Nov 20, 2017 3:17 pm
Oooh. Duh.
Screen Shot 2017-11-20 at 4.16.21 PM.png (109.54 KiB) Viewed 804 times
Mon Nov 20, 2017 6:50 pm
well now it is in sync... I need a snapshot of a situation when it is down and green
Mon Nov 20, 2017 8:49 pm
Here you go. Thought it was green & down before.
Screen Shot 2017-11-20 at 9.47.25 PM.png (146.96 KiB) Viewed 758 times
Tue Nov 21, 2017 7:55 am
Wed Jan 31, 2018 9:59 am
I'm returning to this after having other irons in the fire for a long time.
I still see lots of mismatched icons and statuses in the main window, and in the device status window. I'm running v.7.9.72
For example:
Screen Shot 2018-01-31 at 10.54.25 AM.png (124.39 KiB) Viewed 418 times
Screen Shot 2018-01-31 at 10.58.44 AM.png (13.28 KiB) Viewed 418 times
This is one example, but I count over a dozen devices listed as " down". Notably, nothing is " up" or green and expired.
I'm remote from the machine today, but I may get a chance to try .73.
