Sierrra - Failed to establish connection w interface
Mon Nov 13, 2017 8:31 am
davidgiller221@gmail.com offline
OK - so one of my family members upgraded my Mac to the latest OS.
Now Indigo doesn't work.
HELP!
What should I do?
See attached screenshot and logs.
2017-11-13 Events.txt
Log
(22.08 KiB) Downloaded 96 times
Screenshot
Mon Nov 13, 2017 8:42 am
autolog offline
Re: Sierrra - Failed to establish connection w interface
I don't use Insteon but I suspect that you need to go to the Indigo menu Interfaces >Insteon/X10 Power Line > Configure... and select the USB port for your Powerline 2414U. :)
Mon Nov 13, 2017 8:43 am
Sierra or High Sierra? You say Sierra, which typically works fine, but you also say High Sierra, which there are known USB problems with. One is 10.12. The other is 10.13.
However, this screenshot looks like you just need to run the installer again. EDIT: or as mentioned, re-enable the interface.
Also, it's time to change the admin password :D
