Neo Coolcam Siren
Fri Sep 22, 2017 5:49 am
Colly offline
Neo Coolcam Siren
As mentioned on a separate topic I received the Neo Coolcam Siren today. All parameters are easily changeable and appear to work, different tones and music along with volume etc. For the price it seems to have been well worth the punt. Hopefully Matt/Jay get around to including a new device definition for it in the near future - no real urgency on my behalf :) If there are any other details or testing required please ask.
I concur with other posts around the build quality, seems pretty solid. The documentation is also very reasonable too.
Sync log below:
Indigo Z-Wave Version: 2.0.68
Node ID: 79
Model: Siren
Model ID: 00031088
Manufacturer: Unknown
Manufacturer ID: 0258
Protocol Version: 4.38
Application Version: 2.94
Model Definition Version: 0
Library Type: 6
Class Name: Siren
Class Hierarchy: 04 : 10 : 05
Command Class Base: 25
Command Versions: 20v1 80v1 25v1 86v1 87v1 70v1 71v1 72v1 73v1 59v1 5Av1 5Ev1 85v1
Features: routing, battery, beaming, frequentWaking
Neighbors: 13, 14, 15, 19, 30, 43, 44, 46, 58
Associations: 1:[1] 2:[] 3:[]
Config Values: - none -
Sat Sep 23, 2017 1:55 pm
Re: Neo Coolcam Siren
Thanks for the details. Do you have any docs or a PDF on what the config parameters are?
Sat Sep 23, 2017 2:57 pm
CliveS offline
Matt,
Uploaded Neo Coolcam Z-wave Siren Alarm.pdf in a zip file with a .txt extension!!!! as it won't allow zip or pdf to be uploaded!
CliveS
Neo Coolcam Z-wave Siren Alarm.pdf.zip.txt
(319.87 KiB) Downloaded 147 times
CliveS
Sat Sep 23, 2017 4:28 pm
You can just email stuff like that to us. We want to make sure that the forums don't end up getting huge with attached files (which is why we only allow certain types).
Sat Sep 23, 2017 5:42 pm
Colly offline
Just to confirm the attached manual is the one I received with my device.
Thu Oct 19, 2017 6:36 am
Colly offline
Thanks Matt for the quick inclusion of this new device in 7.1.
I have a general query.
This device has multiple different sounds, volumes etc. I can set one of these on the actual device which is fine, however if I want to have triggers that play a different sound for each one how is this best handled? Is it plugin territory? Or just my old "friend (not)" Python? Maybe there is an easy way that I'm just not familiar with??
Sat Oct 21, 2017 3:13 pm
Not sure how well it would work, but there is a Z-Wave action to Modify the Config Parameter on a device so you could modify it to the sound you want before you turn on the siren?
Sat Oct 21, 2017 4:13 pm
Colly offline
I'll give that a go, once there's not much of a delay it should be fine. Seems a waste to have all those different options and then just picking one...
Thu Nov 09, 2017 7:30 pm
Indigo 7.1.1 is now available for download and includes support for the Neo CoolCam Siren, including UI for configuration parameters.
Tue Jul 10, 2018 5:36 am
tazswe offline
When I configured the siren I found out that the duration for door alert is not in seconds, it’s the number of times the sound will play.
Is it possible to use python to automatically configure the siren so it would play different sounds depending if I use it as an additional doorbell alarm with different sounds for either of my entrances or as an alarmsound for fire, leakage etc.
Tue Jul 10, 2018 5:52 am
tazswe offline
I found the answer in this tread :oops:
