IWS stopped working?
Wed Oct 25, 2017 12:05 pm
Not sure where to put this. Matt/Jay please move as necessary.
My IWS plugin stopped working. Now when the remote server tries to do a GET to my plugin I get this error:
   WebServer                       undefined page requested "http://flyingdiver.goprism.com/twilio/ping" from 34.229.219.100
That URL is correct, it hasn't changed. The IWS setup is right, I think. See attached screen shot. And here's the actual code:
import cherrypy
from indigopy.basereqhandler import BaseRequestHandler
def PluginName():
   return u"Twilio Ping"
def PluginDescription():
   return u"This is the Twilio Ping Plugin."
def ShowOnControlPageList():
   return False      # if True, then above name/description is shown on the Control Page list index
class TwilioRequestHandler(BaseRequestHandler):
   def __init__(self, logFunc, debugLogFunc):
      BaseRequestHandler.__init__(self, logFunc, debugLogFunc)
    def index(self, name=None):
        logmessage = "Twilio Ping usage: http://host:port/twilio/ping\n\n"
        self._Log(logmessage)
        cherrypy.response.headers['Content-Type'] = 'text/plain'
        return logmessage
    index.exposed = True
   def ping(self, **params):
      cherrypy.server.indigoDb.VariableSetValue(cherrypy.server.indigoConn, "twilio_ping", "true")
        return "Twilio Ping Ack"
   ping.exposed = True
Any ideas?
Screen Shot 2017-10-25 at 2.03.02 PM.png (196.2 KiB) Viewed 2298 times
Wed Oct 25, 2017 12:12 pm
Re: IWS stopped working?
Stop and restart the Indigo Server. Any relevant lines logged from the Indigo WebServer?
Wed Oct 25, 2017 12:23 pm
Not that I can see:
   WebServer                       started on port 8176 -- digest authentication enabled
   WebServer                       undefined page requested "http://flyingdiver.goprism.com/twilio/ping" from 54.226.132.114
Should there be something in there registering the IWS plugin?
Wed Oct 25, 2017 12:29 pm
It should log if there is an error loading the plugin.
Is your other plugin (variable_url_redirect) working?
Wed Oct 25, 2017 12:57 pm
Hmm. Yes. At least, I get the usage message if I request the index page. Which doesn't work on the other plugin.
Wed Oct 25, 2017 1:10 pm
It started working again.
I edited the reqhandler.py file and made sure there weren't any weird characters or tabs in it. Deleted the .pyc files, and restarted the server a couple times. Damifino.
Wed Oct 25, 2017 1:15 pm
What you saw might have happened had the indents not been perfect on this line I think:
ping.exposed = True
One of my least favorite things about Python.
