UniFi WiFi AP: download
Mon Jun 19, 2017 8:38 am
Re: uniFi WiFi AP: download
posted v 7-4-39
added:
.-- minor reduction in writes to indigo (for the state image )
-- now supports Fast Roaming option: https://help.ubnt.com/hc/en-us/articles/115004662107-UniFi-Fast-Roaming
recognized besides "Zero-HandoffRoaming"
When devices switch between access points the plugin recognizes it for both options
Zero Handoff started to deteriorate in my environment. After I switched to FastRoaming the performance (throughput) is much better. The switching time is almost not noticeable. I can walk through the house with wifi calling and switch from one AP to the next without loosing the connection. Even as they are on different Wifi bands. You might hear a little "scratching" noise for ~ 0.5 secs.
Fri Jul 07, 2017 9:18 pm
posted v 7-4-42
added fix if device is being created, but it already exists .. should be a very rare event == should not happen
Thu Jul 27, 2017 11:42 am
posted v 7-4-43
minor fix:
if device "notes/ description" needed update the plugin had a debug statement left over from development. It was always printing device name and new device notes.
Now it only does that if debug level is set to "dict details"
Sat Jul 29, 2017 8:27 pm
posted v 7-5-44
added:
option in config to enable/ disable update of the notes/ description field.
If enabled (default): the notes field get updated with changes in the device info from unifi AP/ switch/ GW..
If NO: it only gets set at creation time. Then you can set it to anything you like.
The default will make sure it has a sortable IP number at the beginning.
Wed Sep 27, 2017 8:39 pm
posted v 7.5.46
fixed:
new devices were not created all the time if they only are visible to the unit-switch.
i.e. devices that do not request an IP# from the DHCP server or that do not connect to the outside world i.e. do not go through the gateway / router
This only affects a setup that has a unifi switch .
Sun Oct 01, 2017 9:28 pm
posted V 7.6.50
added:
- now supports up to 5 unifi switches(#0-#4) and will show which "client" is connected at with port for each switch.
Even if not directly connected somehow each client belongs to a port of all the switches = path to that client goes through that port...
- improved the algorithm if you have > 1 Apps or switches to determine if a client device is up/down
- when starting it will check if the internet works. If not it will not check the vendor name for devices through a web call - e.g. MAC = 00:04:a3:ad:a5:cb is a "MICROCHIP TECHNOLOGY INC." device . it would take 10 seconds per devices to timeout. .. that could be a long time for 100 devices
- device states "inListXXX" now show if the unifi device has the client in its internal database. It shows e.g.
--- U>2017-10-01 22:17:44 = last up at 2017 ... or
--- D>2017-10-01 22:14:25 = down device , the last time stamp the client was in that unifi device database
- added state: "lastStatusChangeReason". can be e.g.
--- Period Check DHCP expired
--- DICT SWITCH_0 up
---DICT WiFi 192.168.1.4 up else
--- Period Check Wifi expired
--- etc
useful to see WHY a device went up / down
- added new fields:
---- model: now shows the better formatted info on the model of the unifi devices
---- overheated: show 0/1 if the device has the over heat flag ON/off
unifi devices = unifi switches, gateway, wifi AP
client = the devices connected to your network = MAC, raspberry cameras ...
Wed Oct 04, 2017 10:01 am
posted
-v-7.6.51
fixed
uniFiAP in Line '2858' has error='addToStatesUpdateList() got an unexpected keyword argument 'reason''
only happens under specific circumstance. One of those bugs you need to wait for to happen
thanks to Wouter for pointing it out
Tue Oct 10, 2017 3:44 pm
posted v 7.6.51
changed:
all variable / device/folder names are now using _ instead of - characters.
This for stable performance as indigo does not support fully a - in names .
Tue Oct 10, 2017 5:06 pm
Different Computers online
Thanks again for a critical piece of my HA setup. It's virtually problem free and does more than I ask of it. Five stars!
Tue Oct 10, 2017 5:57 pm
Thanks for testing.
Wed Oct 11, 2017 7:28 am
posted V 7.6.53
fixed:
logging to a file did not work
added;
you now can choose your folder names in config for
- newly created regular devices
- system devices (AP,GW,SW)
- neighbors
Thu Oct 12, 2017 3:12 pm
posted v 7-6-54
removed a leftover debugging statement
viewtopic.php?f=199&t=16182&p=116929#p116929
Sat Oct 21, 2017 12:25 pm
posted V 7.7.55
fixed:
the 8 port switch only showed 7 pots in indigo states. now 8
added
==now supports up to 7 switches (from5 .. as my environment grows..)
== shows in the switch port states:
Screen Shot 2017-10-21 at 13.14.44.png (105.93 KiB) Viewed 15988 times
port_xx =
#D = # of clients (regular devices) attached
SW# = which other unifi switch is connected at this port
GateW = if the UGA is connected at this port
FD/HD -xxx = Full duplex/ half duplex, xxx =10,100,1000Mbit/s type of connection
err: $ of error packages
rx-tx[kb/s] = kb/s received/ send on this port
Mon Oct 23, 2017 10:03 am
posted v 7-8-58
added: Menu / action to power cycle individual ports on unifi switches.
In the menu option (similar in actions) choose Power cycle .. and fill out:
Screen Shot 2017-10-23 at 11.00.16.png (24.43 KiB) Viewed 15964 times
click execute.. it takes ~ 1 second to finish
remember the ports number from1....xx not 0...xx
happy recycling
App: powercyle RPI connected to POE to unifi switches, or powercyle the unifiAP's or cameras ...
it does the following:
ssh userid@x.x.x.x
.. enter password ...
telnet localhost 23
enable
configure
interface 0/PPPP
poe opmode shutdown
poe opmode auto
exit
exit
exit
where x.x.x.x is the IP number of the switch ; PPPP is the port number you want to cycle and userid is the userid of your unifi system (same for everything)
Tue Oct 31, 2017 4:29 pm
new version V-7-9-63 posted:
added, better:
= significantly improved algorithms for Up/down determination
= reduced writes to indigo by ~ factor 20, if you have a lot of Unifi Devices e.g.: with 8 switches, 3 AP, one UGA ,80 IP devices from 30 updates/second to one every 3 secs.
this requires that some of the timers etc have to be non indigo/device/states or properties .. that took most of the time.
= added POE information of switch ports:
poe1 = on, poe0 = off, poeP = pass through
= switch:port info:
---which port is the Client connected to
--- link info: for >= 2 switches you will see with port is connected to which switch:port
#C: 10;DwL:5,P:1;FD-1000; err:264; rx-tx[kb/s]:1-1 =
-- 10 clients connected
-- this is a down link to switch#5
-- connection is FD 1000Mbit
-- # of error packages = 264
-- rx-tx rate: 1kbit
#C: 01;poe1;FD-100; err:0; rx-tx[kb/s]:9-199
-- similar with poe on and client active
== 2 separate options to check UP-> down with a ping and/OR down-->up
== added several reports
== set global parameters for all devices for up/down
== show stats of updates ...
== track all messages info for a specific device (select a MAC#) then all messages and DICT info for THAT device will be shown in the log file. this is good to understand why e.g. status goes up/down, and how to tune your etc .. parameters
When you install the new version you will see a lot of indigo messages that states where removed and added.
I have tested this one for some time, but there will likely be some bugs..
