Condition with minus celcius
Tue Oct 10, 2017 12:06 pm
mortenkols offline
Im setting up and condition based on the outside temperature. But I can't get it to execute. its working if the temperature is between 0-100 degrees, but when i try between -6 and 7 nothing happen. The outside temp is around 5 degrees now.
What is wrong with my condition ?
Skjermbilde 2017-10-10 kl. 20.02.35.png (25.67 KiB) Viewed 1994 times
Skjermbilde 2017-10-10 kl. 20.02.02.png (56.21 KiB) Viewed 1994 times
Tue Oct 10, 2017 3:34 pm
Re: Condition with minus celcius
Could the problem be that the "-" in front of the 6 is a hyphen and not a minus/negative sign? Does it work if you change it from -6 to 0 (given then current temperature is around 5 degrees)?
Tue Oct 10, 2017 3:41 pm
mortenkols offline
yes. it works if I set the condition from 0 to 6. what sign should I use as negative?
Tue Oct 10, 2017 3:52 pm
Just the key to the right of the zero key.
Tue Oct 10, 2017 10:57 pm
mortenkols offline
I have tryed this ‘-‘ sign.
Wed Oct 11, 2017 2:27 pm
I just tried, and I'm unable to reproduce this problem. Using a negative value for the lower bounds of a between conditional worked correctly here.
Are you accessing the Indigo Server from the Indigo Client (GUI) on the same Mac? I'm wondering if an extra invisible character is getting entered in the edit field before or after the number somehow. That is the only way I can think that it would fail to recognize the entry as a number.
Thu Oct 12, 2017 3:53 am
mortenkols offline
Im accessing indigo server from a remote macbook air. Indigo server is on a mac mini with no display
Thu Oct 12, 2017 6:29 am
I think that might be the problem. We've had problems with screen sharing inserting invisible characters on the registration code entry dialog, so the same thing might be happening here.
Are you accessing it remotely using the Indigo client, or via screen sharing?
Maybe try copy/pasting the entire value "-6" to see if that gives a different result?
Thu Oct 12, 2017 10:51 am
mortenkols offline
I have tried indigo client, screen sharing and copy the value you posted. I have also connected mouse and keyboard to the Mac mini server. nothing works.
As you can se from the two pictures, the minus sign changing(longer minus sign) after i save the schedule, if you understand me.
Skjermbilde 2017-10-12 kl. 18.51.13.png (53.23 KiB) Viewed 1757 times
Skjermbilde 2017-10-12 kl. 18.50.58.png (59.78 KiB) Viewed 1760 times
Thu Oct 12, 2017 10:52 am
What version of Indigo are you running?
Thu Oct 12, 2017 10:55 am
mortenkols offline
se my last post again. I edited it with another picture.
I use 7.0.3
Thu Oct 12, 2017 11:05 am
Get it into the state where it is failing (condition evaluation should be true but isn't working), then choose the Indigo 7->Stop Server menu item and email us (support AT indigodomo DOT com) your database file. We'll try to reproduce it here with your database.
Thu Oct 12, 2017 11:17 am
mortenkols offline
i have sent the database now.
I think the problem is that the minus sign is changing format.
Thu Oct 12, 2017 11:33 am
Go to System Preferences, Keyboard Panel, Text tab. Check for a substitution there. Also try unchecking the "Use smart quotes and dashes" box.
Thu Oct 12, 2017 12:12 pm
mortenkols offline
I tried it, but I have the same problem.
