Relays, on off time
Wed Oct 11, 2017 6:22 am
Asconasny offline
Relays, on off time
hi,
trying out some pi´s with relays connected to them.
I have a respons time when clicking on/off at 2-3 seconds.
click on in indigo client--> 2-3 seconds relay turns on.
click off in indigo client--> 2-3 seconds relay turns off.
Is this normal?
When using door/windows sensors, the on/off change for the sensor in Indigo client is near to instant.
Wed Oct 11, 2017 10:36 am
Re: Relays, on off time
how do you set the relays on/off indigo device or action?
and which version are your running?
also could you check time stamps on your mac and RPI
open terminal type date
and switch on debug "output", I believe
there you can see WHEN the message gets send to theRPI. if that is delayed, it is the plugin, if it sends right away, it is the RPI time
Wed Oct 11, 2017 12:21 pm
Asconasny offline
Indigo Device and also tried with action, same result.
Latest version of the plugin.
With output debug enable i can see the plugin sends instantly after i press ON.
When i ping the pi the average response is 0.681ms
RPI time matches the mac time doing the date command
These are the first RPI versions but would´nt think thats an issue.
Wed Oct 11, 2017 3:34 pm
i tried.. no delay < 0.5 secs..
ok could you set debug output to high in the lower section of config (RPI)
then ssh pi@..
with
tail -f /run/user/1000/pibeacon/execcommands.log
you should see something like this when you switch device off/on in indigo
20171011-16:29:12 next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'26', u'inverseGPIO': False, u'command': u'down', u'device': u'OUTPUTgpio-1-ONoff'}
20171011-16:26:41 next command: {u'restoreAfterBoot': u'0', u'startAtDateTime': 0, u'pin': u'26', u'inverseGPIO': False, u'command': u'up', u'device': u'OUTPUTgpio-1-ONoff'}
if >>> u'startAtDateTime': 0 << , is right .. and these line apple immediately :
next thing to check is:
= how is the relay connected?
= can you manually trigger the relay, connect the relay board input pin to +3.3 and 0 and see if it clicks immediately
