To use this in a Refreshing Image URL on a control page, you specify the url:
- Code: Select all
http://USERNAME:PASSWORD@localhost:8176/variable_url_redirect/redirect?name=VARIABLENAME
You substitute the appropriate information for the words in ALLCAPS. The username and password are the username and password for your Indigo Server as you specified it in the Start Local Server... dialog. You pass in the variable name (not the id).
Note: this plugin will only work with http/https URLs (not file URLs for instance) and doesn't support authentication in the URL that's stored in the variable value.
If you changed the port for the Indigo Web Server you'll need to use your custom port number. The above should work for most people though.
Note that you can also do this from a browser just by hitting the URL above.
