DSC not working after transfer to new computer
Sun Jul 16, 2017 6:22 am
pgershon offline
DSC/Envisalink-3 moved to new computer and stopped working. See error messages below. Not sure what is going on:
Jul 16, 2017, 8:17:30 AM
   Error                           script error: «script» doesn’t understand the “GetsxmStation” message. (-1708)
   DSC Alarm                       Initializing communication at address: 192.168.1.191:4025
   DSC Alarm                       Communication established
   DSC Alarm Error                 Connection RX Error: connection failed ([Errno 54] Connection reset by peer)
   DSC Alarm Error                 Connection TX Error: socket connection failed: [Errno 32] Broken pipe
   Error                           plugin "DSC Alarm 2.1.0" (pid 47914) unexpectedly stopped -- restarting in 5 seconds
   Reloading plugin "DSC Alarm 2.1.0"
   Starting plugin "DSC Alarm 2.1.0" (pid 47919)
   DSC Alarm                       Log level preferences are set to "Normal".
   Started plugin "DSC Alarm 2.1.0"
   Error                           plugin "DSC Alarm 2.1.0" (pid 47919) unexpectedly stopped -- restarting in 20 seconds
   Starting plugin "DSC Alarm 2.1.0" (pid 47920)
   Error                           plugin "DSC Alarm 2.1.0" (pid 47920) unexpectedly stopped -- restarting in 20 seconds
Sun Jul 16, 2017 6:27 am
pgershon offline
Re: DSC not working after transfer to new computer
I rebooted the Envisalink on its webpage software and that fixed the issue.
Wed Jul 26, 2017 7:27 pm
pgershon offline
So I need to reactivate this. The problem came back after about 1 week of working Any ideas what would cause this problem to recur? Perhaps a temporary power failure?
Wed Jul 26, 2017 11:30 pm
Korey offline
Looks like network issues.
Korey
Thu Jul 27, 2017 1:56 am
durosity offline
I seem to recall you get that message if something else is already connected to the Envisalink which can only handle one connection at a time (which is annoying as i now have 2.. one for Indigo and one for HomeBridge-Envisalink) so you might wanna check your old machine isn't establishing a connection. You could also try power-cycling your alarm system to reset the envisalink.
Sat Aug 05, 2017 3:45 pm
johnfdl offline
Also, remember, only one system can be connected to Envisalink. So when I transferred from one system to another, my Envisalink kept failing with the new system because it was still connected to the old one. Just throwing that out there in case it helps.
