Error when unlock trigger fires
Thu Jun 15, 2017 9:25 pm
srkinard offline
I've had the Lock Manager pretty much since it was released, and one function was to send an email whenever a user unlocks the front door deadbolt.
I updated the plugin to 1.0.37 a few weeks ago, and created the Placeholder device for the lock as instructed. I made sure all the triggers pointed to the new device and all...so it looked fine.
I realized earlier that I had not seen any emails about the lock...so I took the laptop and watched Indigo while I triggered it myself...I saw this error in the logs:
   Z-Wave Lock Manager             Status: Door locked manually [Node: 65]
   Z-Wave                          received "Lock - Front Door Deadbolt" status update unlocked by user 001 (via keypad)
   Trigger                         Front Door Unlocked
   Z-Wave Lock Manager             Status: User 1 unlocked door [Node: 65]
   Z-Wave Lock Manager Error       Error in plugin execution ReceivedBroadcast:
  File "plugin.py", line 290, in zwaveCommandReceived
  File "plugin.py", line 526, in triggerEvent
KeyError: (94353879,)
   Z-Wave                          received "Lock - Front Door Deadbolt" status update locked (manually)
   Trigger                         Front Door Locked
Did I miss another step in converting from the old version to the new?
Ross
Thu Jun 15, 2017 11:35 pm
Re: Error when unlock trigger fires
Hi Ross.
No, there's about 5 users waiting for me to fix this; it will be sorted this weekend.
Peter
Thu Jun 15, 2017 11:43 pm
srkinard offline
howartp wrote:
Hi Ross.
Peter
Awesome...thanks Peter!
Fri Jun 16, 2017 11:39 am
Give 1.0.38 a try... (same link)
Peter
Sun Jun 18, 2017 9:10 am
CliveS offline
Peter,
Updated to .39 and getting these errors
18 Jun 2017, 11:02:40
Z-Wave received "Front Door Keypad Lock" status update unlocked (manually)
Z-Wave Lock Manager Status: Door unlocked manually [Node: 55]
File "plugin.py", line 300, in zwaveCommandReceived
File "plugin.py", line 534, in triggerEvent
KeyError: ('unlockedManually',)
Z-Wave received "Front Door Keypad Lock" status update locked (via timer)
Z-Wave Lock Manager Status: Door re-locked automatically [Node: 55]
File "plugin.py", line 320, in zwaveCommandReceived
KeyError: ('relockedAuto',)
18 Jun 2017, 11:03:39
Z-Wave received "En Suite Floor Heating Thermostat" heat setpoint is 15.0 °C
Z-Wave received "Front Door Keypad Lock" status update locked (manually)
Z-Wave Lock Manager Status: Door locked manually [Node: 55]
File "plugin.py", line 294, in zwaveCommandReceived
KeyError: ('lockedManually',)
18 Jun 2017, 11:04:45
Z-Wave received "En Suite Floor Heating Thermostat" mode is off
CliveS
CliveS
Indigo 7.4.0 : MacOS Catalina 10.15.1 : Mac mini Server (Mid 2011) : 2 GHz Core i7. : 8 GB. : 2 x 256GB Samsung EVO SSD
Sun Jun 18, 2017 2:35 pm
Oops.
There's a line in my code that says:
self.events = dict() # {} Need to define here any new Trigger types or the key throws undefined errors
This is to remind me that whenever I define new triggers, I gotta initialise them here or else they throw errors.
I forgot....!
v1.0.40 now live.
Peter
Sun Jun 18, 2017 3:30 pm
CliveS offline
That eradicated the critter :)
18 Jun 2017, 22:23:08
WebServer request to execute action group "Front Door Unlocked" from xx.166.158.xx
Action Group Front Door Unlocked
Z-Wave sent "Front Door Keypad Lock" unlock
Z-Wave received "Front Door Keypad Lock" status update unlocked (via controller)
Z-Wave Lock Manager Status: Door unlocked by Indigo [Node: 55]
WebServer request to execute action group "Front Door Locked" from xx.166.158.xx
Action Group Front Door Locked
Z-Wave sent "Front Door Keypad Lock" lock
Z-Wave received "Front Door Keypad Lock" status update locked (via controller)
Z-Wave Lock Manager Status: Door locked by Indigo [Node: 55]
CliveS
CliveS
Fri Jun 23, 2017 1:27 pm
roquej offline
I am still getting the following error:
Z-Wave Lock Manager Status: User 1 unlocked door [Node: 127]
File "plugin.py", line 299, in zwaveCommandReceived
File "plugin.py", line 548, in triggerEvent
KeyError: (845063353,)
Version is .40
Any suggestion?
JP
Sat Jun 24, 2017 4:08 pm
Off the top of my head, have you created dummy device(s) for the lock(s)?
