Sensitive Strips
Fri Apr 21, 2017 9:27 am
petematheson offline
Sensitive Strips
Hi All / Matt & Jay!
My Sensitive strips show up as On/Off in indigo.
Is it possible to get this changed to Open / Closed? Since they're door & window sensors it would make sense no?
Fri Apr 21, 2017 10:25 am
Re: Sensitive Strips
Good idea!
Fri Apr 21, 2017 10:27 am
Indigo doesn't currently have a native "Door" type, with open/closed states. So until it does, you're stuck with on/off.
I have the same problem with the MyQ plugin. There, I'm defining the doors as lock devices, with locked == closed and unlocked == open.
Fri Apr 21, 2017 10:31 am
Yes, this is definitely on the request list. Some of the work has been done for it, but not quite enough to enable it for consumption yet.
Fri Apr 21, 2017 10:34 am
Ah ok! My DSC alarm sensors all show as open / close so thought it might be simples
Fri Apr 21, 2017 10:35 am
That's the plugin doing that special.
Fri Apr 21, 2017 10:54 am
I'll race you to it...
Fri Apr 21, 2017 2:20 pm
autolog offline
Take a look at the Adapters Plugin by dustysparkle.
I use it to show my window curtains as Open or Closed - It works well :)
Fri Apr 21, 2017 10:58 pm
CliveS offline
I agree with
This is my settings for my Sensitive Strip using the Adaptors Plugin giving me a Window Open and Window Closed. - ( thanks dustysparkle )
CliveS
CliveS
Sat Apr 22, 2017 4:03 pm
Looks to be very handy!
Just a shame it duplicates all of the sensors - think I'll hang fire until (possibly) this is updated to do it natively :)
Sat Apr 22, 2017 5:12 pm
It does, but you can hide (untick Remote Display) the original device, and/or move it onto a folder called Base Devices, which has Remote Display turned off at folder level.
That's what I do for one or two other bits.
