- Posted on
Thu Oct 24, 2019 2:33 am
siclark
offline
I have had to install one of my qubino dual relays that have sat in a drawer for a year or more as I have a new circuit I need to control.
On and off are working ok but the power reporting is strange.
When on it seems to be ok, but when its turned off it consistently reports approx 77W, which is ihigher than when on.
This is the log of a power request when off, showing 78.9W, then turning it on showing power drops to 66.6W, tthen when its turned off it increases again to 77.7W. I have resynced it but not tried hard reset yet. Anyone seen this behaviour before? I know there were issues a few years ago with these reporting power but this seems to be on the device itself and not on the reporting to Indigo?
Simon
Z-Wave sent "Patio Spot Lights" energy status request
Z-Wave Watcher Debug Raw command sent (Node 28 Endpoint 2): 01 0E 00 13 1C 07 60 0D 01 02 32 01 00 25 DC 5D (True)
Z-Wave Watcher Debug Raw command received (Node 28 Endpoint 2): 01 14 00 04 00 1C 0E 32 02 21 24 00 00 00 D6 00 01 00 00 00 D6 FF
Z-Wave Watcher Debug Raw command received (Node 28): 01 18 00 04 00 1C 12 60 0D 02 01 32 02 21 24 00 00 00 D6 00 01 00 00 00 D6 B7
Z-Wave Watcher Debug Raw command sent (Node 28 Endpoint 2): 01 0E 00 13 1C 07 60 0D 01 02 32 01 10 25 DD 4C (True)
Z-Wave received "Patio Spot Lights" power load to 78.9 W
Z-Wave Watcher Debug Raw command received (Node 28 Endpoint 2): 01 10 00 04 00 1C 0A 32 02 21 34 00 00 03 15 00 00 FF
Z-Wave Watcher Debug Raw command received (Node 28): 01 14 00 04 00 1C 0E 60 0D 02 01 32 02 21 34 00 00 03 15 00 00 A0
Z-Wave sent "Patio Spot Lights" on
Z-Wave Watcher Debug Raw command sent (Node 28 Endpoint 2): 01 0E 00 13 1C 07 60 0D 01 02 25 01 FF 25 E0 89 (True)
Z-Wave Watcher Debug Raw command received (Node 28 Endpoint 2): 01 09 00 04 00 1C 03 25 03 FF FF
Z-Wave Watcher Debug Raw command received (Node 28): 01 0D 00 04 00 1C 07 60 0D 02 00 25 03 FF 5B
Z-Wave Watcher Debug Raw command sent (Node 28 Endpoint 2): 01 0E 00 13 1C 07 60 0D 01 02 32 01 00 25 E1 60 (True)
Z-Wave Watcher Debug Raw command sent (Node 28 Endpoint 2): 01 0E 00 13 1C 07 60 0D 01 02 32 01 10 25 E2 73 (True)
Z-Wave received "Patio Spot Lights" power load to 66.6 W
Z-Wave Watcher Debug Raw command received (Node 28 Endpoint 2): 01 10 00 04 00 1C 0A 32 02 21 34 00 00 02 9A 00 00 FF
Z-Wave Watcher Debug Raw command received (Node 28): 01 14 00 04 00 1C 0E 60 0D 02 01 32 02 21 34 00 00 02 9A 00 00 2E
Z-Wave sent "Patio Spot Lights" off
Z-Wave Watcher Debug Raw command sent (Node 28 Endpoint 2): 01 0E 00 13 1C 07 60 0D 01 02 25 01 00 25 E3 75 (True)
Z-Wave Watcher Debug Raw command sent (Node 28 Endpoint 2): 01 0E 00 13 1C 07 60 0D 01 02 32 01 00 25 E4 65 (True)
Z-Wave received "Patio Spot Lights" power load to 77.7 W
Z-Wave Watcher Debug Raw command received (Node 28 Endpoint 2): 01 10 00 04 00 1C 0A 32 02 21 34 00 00 03 09 00 00 FF
Z-Wave Watcher Debug Raw command received (Node 28): 01 14 00 04 00 1C 0E 60 0D 02 00 32 02 21 34 00 00 03 09 00 00 BD
Z-Wave Watcher Debug Raw command sent (Node 28 Endpoint 2): 01 0E 00 13 1C 07 60 0D 01 02 32 01 10 25 E5 74 (True)
Z-Wave Watcher Debug Raw command received (Node 28): 01 14 00 04 00 1C 0E 60 0D 02 01 32 02 21 34 00 00 03 09 00 00 BC
