Could you share your jsons? And the link ?
virgahyatt wrote:kw123 wrote:Yes that's the plan
Has anyone setup a UniFi router and could share how to set it up?
I have gone through it and the setup is pretty painless. But there is one rather big snag when using macs with it that I ran across Back To My Mac. Which uses some of the same ports as VPN and if uPnP is also enabled on the edge router it will prevent either one from working right. So make sure you turn it off on all the computers used in the house or disable uPnP. They have walkthroughs available that will take you setting it up and making sure the firewall rules are setup.
"config_port_table": [
"ifname": "eth0",
"name": "wan"
"ifname": "eth1",
"name": "lan"
"ifname": "eth2",
"name": "wan2"
config_network_ports": {
"LAN": "eth0",
"WAN": "eth2",
"WAN2": "eth3"
