feature req. OUTPUT-GPIO-max-1-PIN without dimmer
Sun Mar 26, 2017 9:34 am
Asconasny offline
Hi.
Ive been using a couple arduino´s for a while and wanted the ibeacon feature.
Well.. im super impressed with this plugin, going to replace my arduinos with some pibeacons.
Excellent work on this. Karl :)
Maybe im missing something.. but is it possible to make a on off device, that behave like the like the output-gpio1 dimmer?
Without the dimmer part, but with on off switch in the indigo ui.
regards
Asconasny
Sun Mar 26, 2017 8:40 pm
Re: feature req. OUTPUT-GPIO-max-1-PIN without dimmer
the difficult part was to make it like a dimmer.. so the only things thats not good for you is the UI?
you can set to 0/100 for on/off
But I could just make it a non dimmer on/off.. will check
KArl
Sun Mar 26, 2017 9:32 pm
http://forums.indigodomo.com/viewtopic.php?f=187&t=15152&p=136992#p136992
that was easier than I thought .. if you could try it.
choose OUTPUT-GPIO-1-ONoff as device type
Mon Mar 27, 2017 1:46 am
Asconasny offline
Hi Karl
Tried it! It works perfectly
Exactly what i wanted. Thanks :)
Just started using the pibeacon. All the xy beacons you sendt me working perfect.
Some questions:
If a powerfailure, does the pi know the state of the gpio pin it was in, when the power gets back?
Is that being stored somewhere?
Is it possible to run some singel Neopixel Leds on the pi?
And configure it with the plugin?
Would be awesome to use that as a status light for a variable or device. Say. house in nightmode, morning, etc
or alarm. armed, armed home, etc.
One led to rule them all :)
And thinking about the camera. Is that possible or would it interfere with the plugin?
regards
Asconasny
Mon Mar 27, 2017 6:31 am
When you set the output through an action there is an option to restore After restart
You can use the rpi gpio out in dummer mode. That actually does a PWM out put
So for e.g. 50% it switches it on /off with 100 hz But the output is limited to 20mA. If that is enough to drive the device. Ok.
if not You would need to add an amplifier. I am using some large led displays - see the display output options They come with their own system and they work fine.
Mon Mar 27, 2017 7:25 am
after i got up, I looked at it in a bit more detail..
1. pibeacon supports ~ 10 different display types.
2. no neopixel driver yet. but this looks really interesting.. will order a strip and try to set it up . Will be a new device model, displays have many x,y pixels, this stripes have mostly one row
Users browsing this forum: No registered users and 23 guests
