If I just enable the plugin and create the device in indigo, nothing shows up in the dropdown. I attached the UPnP logs below:
- Code: Select all
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:deviceUPNPSeachCacheTime
Sony Bravia Network Remote Plugin Debug Performing uPnP search for: ssdp:all
Sony Bravia Network Remote Plugin Debug Found 4 devices
Sony Bravia Network Remote Plugin Debug Found uPnP Device: <SSDPResponse(http://192.168.1.178:45464/dd.xml, urn:dial-multiscreen-org:service:dial:1, uuid:0d35ffd6-529f-4475-9654-f5d6c9f6d134::urn:dial-multiscreen-org:service:dial:1, FedoraCore/2 UPnP/1.0 MINT-X/1.8.1)>[('usn', 'uuid:0d35ffd6-529f-4475-9654-f5d6c9f6d134::urn:dial-multiscreen-org:service:dial:1'), ('server', 'FedoraCore/2 UPnP/1.0 MINT-X/1.8.1'), ('ext', ''), ('location', 'http://192.168.1.178:45464/dd.xml'), ('cache-control', 'max-age=1800'), ('st', 'urn:dial-multiscreen-org:service:dial:1')]</SSDPResonse>
Sony Bravia Network Remote Plugin Debug Found uPnP Device: <SSDPResponse(http://192.168.1.198:80/description.xml, urn:schemas-upnp-org:device:basic:1, uuid:2f402f80-da50-11e1-9b23-00178812ed7e, FreeRTOS/7.4.2 UPnP/1.0 IpBridge/1.16.0)>[('usn', 'uuid:2f402f80-da50-11e1-9b23-00178812ed7e'), ('ext', ''), ('hue-bridgeid', '001788FFFE12ED7E'), ('host', '239.255.255.250:1900'), ('location', 'http://192.168.1.198:80/description.xml'), ('st', 'urn:schemas-upnp-org:device:basic:1'), ('cache-control', 'max-age=100'), ('server', 'FreeRTOS/7.4.2 UPnP/1.0 IpBridge/1.16.0')]</SSDPResonse>
Sony Bravia Network Remote Plugin Debug Found uPnP Device: <SSDPResponse(http://192.168.1.178:52323/MediaRenderer.xml, urn:schemas-rvualliance-org:service:StreamSplicing:1, uuid:23456789-1234-1010-8000-ac9b0a5b982a::urn:schemas-rvualliance-org:service:StreamSplicing:1, Android/1.6 UPnP/1.0 Huey Sample DMR/0.1)>[('usn', 'uuid:23456789-1234-1010-8000-ac9b0a5b982a::urn:schemas-rvualliance-org:service:StreamSplicing:1'), ('server', 'Android/1.6 UPnP/1.0 Huey Sample DMR/0.1'), ('ext', ''), ('location', 'http://192.168.1.178:52323/MediaRenderer.xml'), ('cache-control', 'max-age=1800'), ('x-av-server-info', 'av=5.0; hn=""; cn="Sony Corporation"; mn="Huey Sample DMR"; mv="0.1";'), ('st', 'urn:schemas-rvualliance-org:service:StreamSplicing:1')]</SSDPResonse>
Sony Bravia Network Remote Plugin Debug Found uPnP Device: <SSDPResponse(http://192.168.1.178:26768/sony/webapi/ssdp/dd.xml, urn:schemas-sony-com:service:IRCC:1, uuid:0d3a9b6f-8806-481c-a914-92ff53962b51::urn:schemas-sony-com:service:IRCC:1, FedoraCore/2 UPnP/1.0 MINT-X/1.8.1)>[('usn', 'uuid:0d3a9b6f-8806-481c-a914-92ff53962b51::urn:schemas-sony-com:service:IRCC:1'), ('server', 'FedoraCore/2 UPnP/1.0 MINT-X/1.8.1'), ('ext', ''), ('location', 'http://192.168.1.178:26768/sony/webapi/ssdp/dd.xml'), ('cache-control', 'max-age=1800'), ('st', 'urn:schemas-sony-com:service:IRCC:1')]</SSDPResonse>
Figuring that the TV was probably 192.168.1.178, I tried entering that address manually, and creating a TV OFF action.
When I ran the action in Indigo 7, I got the following logs and a message on the TV saying "Please enter code 7837 in the device.". There's nowhere in the plugin settings to enter a code, other than maybe "Auth Token", which is greyed out for me.
- Code: Select all
Sony Bravia Network Remote Plugin Threaddebug Returning default GUIConfigValue for sonyTvRemoteDevice:deviceIsChildDevice
Sony Bravia Network Remote Plugin Threaddebug Command queue has 1 command(s) waiting
Sony Bravia Network Remote Plugin Threaddebug Received SOAP/JSON command request:
/sony/IRCC
urn:schemas-sony-com:service:IRCC:1#X_SendIRCC
<SOAP-ENV:Envelope SOAP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:SOAP-ENV="http://schemas.xmlsoap.org/soap/envelope/">
<SOAP-ENV:Body>
<m:X_SendIRCC xmlns:m="urn:schemas-sony-com:service:IRCC:1">
<IRCCCode xmlns:dt="urn:schemas-microsoft-com:datatypes" dt:dt="string">AAAAAQAAAAEAAAAvAw==</IRCCCode>
</m:X_SendIRCC>
</SOAP-ENV:Body>
</SOAP-ENV:Envelope>
Sony Bravia Network Remote Plugin Debug Processing SOAP/JSON operation to http://192.168.1.178:80/sony/IRCC
Sony Bravia Network Remote Plugin Threaddebug Sending SOAP/JSON request:
<SOAP-ENV:Body>
</m:X_SendIRCC>
</SOAP-ENV:Body>
Sony Bravia Network Remote Plugin Threaddebug Using headers:
{'SOAPAction': 'urn:schemas-sony-com:service:IRCC:1#X_SendIRCC', 'Host': u'192.168.1.178', 'Content-type': 'text/xml; charset="UTF-8"', 'User-Agent': 'DuncanwareRemote (IndigoPlugin)'}
Sony Bravia Network Remote Plugin Received an authentication request, attempting now...
Sony Bravia Network Remote Plugin Threaddebug Received an authentication command, attempting connection
Sony Bravia Network Remote Plugin Threaddebug Sending Auth Request: {"id":13, "method":"actRegister", "version":"1.0", "params": [{"clientid":"DuncanwareRemote:34c43339-af3d-40e7-b1b2-743331375368c", "nickname":"DuncanwareRemote (IndigoPlugin)"}, [{"clientid":"DuncanwareRemote:34c43339-af3d-40e7-b1b2-743331375368c", "value":"yes", "nickname":"DuncanwareRemote (IndigoPlugin)", "function":"WOL"}]]}
Sony Bravia Network Remote Plugin Threaddebug Response to Auth Request: [401] [('content-length', '38'), ('content-type', 'application/json'), ('connection', 'close'), ('www-authenticate', 'Basic realm="Private Page"')]
{"error":[401,"Unauthorized"],"id":13}
Sony Bravia Network Remote Plugin Error This device (1850737625) must be paired in order for the plugin to act as a remote.
By the way, the TV and the computer are on different floors, so I'm hoping a limited amount of running up and down the stairs is required.
