Virtual device based off Alarm Keypad device, using 'state'
Tue Jan 17, 2017 11:13 am
blysik offline
I'm trying to create a virtual device (which would be exposed to Homebridge) based off of my DSC Alarm plugin keypad device.
The keypad device has a state of 'disarmed', or 'armed'. I would like this to be somehow used for the Virtual Device's off or on status. How can I accomplish this?
Tue Jan 17, 2017 11:28 am
Colorado4Wheeler offline
Re: Virtual device based off Alarm Keypad device, using 'sta
You can try Device Extensions. This lets you do pretty much precisely what you are asking.
Tue Jan 17, 2017 11:44 am
blysik offline
Aha! So use the "v1.5.3 Conversions: Convert to String (and optionally trim)" functionality? Thanks! I'll give that a try.
Tue Jan 17, 2017 11:49 am
blysik offline
Maybe I'm missing something though. Sure, I could use device extensions that mirrors the state of the keypad correctly. However,it's not a virtual device, so I can't set it's "on" or "off" actions.
Tue Jan 17, 2017 3:03 pm
Try my Masquerade plugin and create a sensor device based on the keypad state.
viewtopic.php?f=216&t=17402
Tue Jan 17, 2017 3:10 pm
blysik offline
Masquerade sensor has the same problem, doesn't it? I can't assign Action Groups to the on/off commands of the masquerade sensor device.
Tue Jan 17, 2017 3:14 pm
Sensor devices have no on/off commands, only on/off status. I thought you were looking for a way to trigger an action group based on the on/off status.
What EXACTLY are you trying to do?
Tue Jan 17, 2017 3:19 pm
blysik offline
I want to create a new device. The device determines its state from my Alarm Keypad device. I can assign an Action Group to the "on", and another to the "off" of the device. Then, I can expose this device to HomeKit via homebridge.
Essentially, a Virtual Device does what I want, EXCEPT I can't use the keypad state to set its status. (Only a variable.)
Thinking about it more, the only thing I can thing of is to use a trigger on the Keypad somehow to set a variable, that the Virtual Device uses. It would be better to get the state directly, in my mind, however.
Tue Jan 17, 2017 3:20 pm
blysik offline
Looking at the triggers, I guess I can do this with native indigo. But it seems a little more hackey then I wanted.
Tue Jan 17, 2017 5:31 pm
  1. Create a trigger that fires whenever the relevant keypad state changes. You'll need to write a simple script that sets the value of a variable (say, armed_status) to on/off based on whatever mapping you want (see below)
  2. Create Action Groups to Arm/Disarm
  3. Create a Virtual On/Off device using the appropriate Action groups and which uses armed_status as it's state.
Script from step 1
keypad = indigo.devices[IDOFKEYPADDEVICE]
if keypad.states["nameOfArmedStateHere"] == "armed":
    indigo.variable.updateValue(IDOFVARHERE, "true")
    indigo.variable.updateValue(IDOFVARHERE, "false")
You may be able to use a different plugin to do the value mapping from the above script but I'll leave that as an exercise for you and/or the community.
Tue Jan 17, 2017 5:34 pm
Or, yeah, you can probably just do it with triggers.
Nothing built-in is a "hack" by definition... ;)
