global name colvaru is not defined
Sat Jan 14, 2017 4:07 am
DomoPat offline
Hello, great plugin with so many possibilities ! I have started to experiment with it, but I have the following error in the log every second:
Line '3389' has error='global name 'colVaru' is not defined'error in setupGNUPlotFiles
I am not using GNUPlot and always used MatPlot in the config menu, plugin version is 4.16.18. What can I do to get rid of the error ?
Thank you,
Patrick
Sun Jan 15, 2017 6:46 am
johnpolasek offline
Re: global name colvaru is not defined
Are you trying to use a polar plot? I started getting that when I tried creating a wind rose from my weather station.
Sun Jan 15, 2017 3:22 pm
DomoPat offline
Yes, I will delete it to check if it removes the error message, will let you know later.
Mon Jan 16, 2017 6:55 am
johnpolasek offline
I not only had to delete the plot, but also restart the plugin before it went away for me. It looks like there is no way to set the DataB column for the plot, which is only required by the polar plot option., I've been meaning to look over Karl's code to see if I could track that down because a wind rose off my weather station would be a neat addition to my weather control page.
Mon Jan 16, 2017 10:00 am
DomoPat offline
Confirmed, the error disappeared after deleting the polar plot and restarting the plugin. Too bad, I also wanted to see the wind rose !
Wed Jan 18, 2017 12:15 pm
sorry just saw this, will look into it this week
