Switch off all devices beginning with text - if switched on
Sun Dec 25, 2016 10:45 am
davinci offline
I want to switch off all devices starting with text light, only if they are on.
What would be the easiest way to do this?
Sun Dec 25, 2016 10:53 am
Re: Switch off all devices beginning with text - if switched
What do you mean "starting with text light"?
Sun Dec 25, 2016 11:09 am
davinci offline
The device is called like this:
Light kitchen
or
Light bedroom
Sun Dec 25, 2016 11:26 am
Something like this:
for dev in indigo.devices.iter():
    if dev.name.startswith("Light"):
        indigo.device.turnOff(dev)
Sun Dec 25, 2016 12:43 pm
davinci offline
Thanks a lot for the quick reply. It helps a lot.
Here is my full script in case someone wants to use this as well.
The goal was to switch off all lights in an efficient way.
- only switch off if really on
- turn off all lights except one (Light Exception)
- wait 1 second between every light to avoid network overload - but only wait if one light has been switched off
import time
    if dev.name.startswith("Light") and indigo.devices[dev].onState and dev.name != "Light Exception":
        time.sleep(1)
Sun Dec 25, 2016 1:58 pm
This version is more efficient since it doesn't get the device from the server twice:
import time
    if dev.name.startswith("Light") and dev.onState and dev.name != "Light Exception":
        time.sleep(1)
Sun Dec 25, 2016 3:47 pm
davinci offline
Thanks jay, for pointing that out.
