I've restarted the Mini, unplugged and plugged again the cable, doesn't work.
Even in the AppleProfiler doesn't comes up as a USB device!
Same cable as with the 10.6.8
Do you know how to uninstall it?
Yassi
apcupsd Error readApcupsd: Connection to apcaccess failed with error code:32512. Attempt 1 of 5
apcupsd Error readApcupsd: Connection to apcaccess failed with error code:32512. Attempt 2 of 5
apcupsd Error readApcupsd: Connection to apcaccess failed with error code:32512. Attempt 3 of 5
apcupsd Error readApcupsd: Connection to apcaccess failed with error code:32512. Attempt 4 of 5
apcupsd Error readApcupsd: Connection to apcaccess failed with error code:32512. Attempt 5 of 5
apcupsd Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 191, in runConcurrentThread
File "plugin.py", line 297, in readApcupsd
TypeError: not enough arguments for format string
apcupsd Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
UPS and Battery Monitor Power Status - AC Power - No Battery
UPS and Battery Monitor UPS Model - No Battery or UPS
UPS and Battery Monitor Charging Status - False
UPS and Battery Monitor Battery Charge - 0
UPS and Battery Monitor Refreshing in 1 Minutes
apcupsd runConcurrentThread called
apcupsd Plugin started. Polling apcupsd server(s) every 4.0 minutes with a timeout of 8 seconds
File "plugin.py", line 256, in runConcurrentThread
AttributeError: 'Plugin' object has no attribute 'logLevel'
Users browsing this forum: Google [Bot] and 15 guests
