Applescript and WeatherCat
Wed Dec 14, 2016 3:50 am
Matt offline
Does anyone have any scripts to move WeatherCat data over to Indigo vairiables?
I was using the following script, but I keep getting the "application is not running. 600" error.
tell application "WeatherCat"
   set wnowInsideTemp to InternalTempDelta1
   set wnowOutsideTemp to ExternalTempDelta1Unconverted
   set wnowInsideHumidity to InternalRHDelta1
   set wnowOutsideHumidity to ExternalRHDelta1
   try
      set wnowRainToday to text 1 thru 4 of (PrecipitationDaily as text)
   on error
      set wnowRainToday to PrecipitationDaily
   end try
   try
      set wnowRainRate to text 1 thru 4 of (PrecipitationPerHourDelta1Unconverted as text)
   on error
      set wnowRainRate to PrecipitationPerHourDelta1Unconverted
   end try
   set wnowForecast to CurrentConditions
   set WorkingChannel to 58
   try
      set annualRain to text 1 thru 5 of ((WorkingChannelValue / 25.4) as text)
   on error
      set annualRain to WorkingChannelValue / 25.4
   end try
end tell
   --set value of variable "wnow_LastUpdate" to wnowTimeStamp
   set value of variable "LWC_GarageTemp" to wnowInsideTemp as integer
   set value of variable "LWC_OutsideTemp" to wnowOutsideTemp as integer
   set value of variable "LWC_GarageHumidity" to wnowInsideHumidity as integer
   set value of variable "LWC_OutsideHumidity" to wnowOutsideHumidity as integer
   set value of variable "LWC_RainToday" to wnowRainToday as real
   --set value of variable "LWC_Forecast_raw" to wnowForecast
   set value of variable "LWC_RainRate" to wnowRainRate as real
   set value of variable "LWC_AnnualRain" to annualRain as real
end tell
Wed Dec 14, 2016 9:52 am
automaton offline
Re: Applescript and WeatherCat
I use an old indigo plugin called LWC (the old weathercat was lightfoot weather center "LWC"). I'm not sure is there are copies around anymore. Puts everything in Indigo variables automatically, and updates them on whatever frequency you would like.
Wed Dec 14, 2016 10:29 am
viewtopic.php?f=4&t=12857
Mon Dec 19, 2016 4:26 am
Matt offline
Thanks, Jay. I looked at that thread before I posted. Still no luck getting the script to run.
Mon Dec 19, 2016 7:43 am
Matt offline
This is weird, but it fixed things. I had to set a variable to another variable before Indigo would recognize it. After that it began updating all the other variable.
Here's the new script (The change is underlined):
   try
   on error
   end try
   try
      set wnowRainRate to text 1 thru 4 of (PrecipitationPerHour as text)
   on error
   end try
   try
   on error
   end try
   using terms from application "IndigoServer"
      [size=150][u]set LWC_GarageTemp to round (wnowInsideTemp)[/u][/size]
      --set value of variable "LWC_GarageTemp" to LWC_GarageTemp
   end using terms from
end tell
end tell
Sun Aug 12, 2018 7:34 am
RWBUMP offline
I use the WeatherCat plugin from GitHub. It was written for Indigo 6.1 but most of the time runs fine on Indigo 7.
https://github.com/psevigny/weathercat
Wed Oct 24, 2018 7:52 am
jenkins007 offline
I've been using WeatherCat for many years and an AppleScript to bring populate many Indigo variables. Since 7.2 and updating to a new computer (running 10.14), the AppleScript started getting errors and stopped updating. So last week I converted the AppleScript to python. It's running well, I am happy to share both the XML template and the python script, but not sure where to post it.
WeatherCat uses a template to create populate an XML file. The python script reads the XML file and parses the data into Indigo variables. The weather values update using an Indigo schedule to execute the python script.
Matthew
Wed Oct 24, 2018 8:39 am
Feel free to zip up the files and add it to the File Library. Then post a pointer in the Integrating Services/Applications forum.
Mon Nov 26, 2018 4:46 pm
daveHawk offline
Unfortunately even though the contribution seems to have been posted, clicking on download results in "File Not Found"
Mon Nov 26, 2018 6:26 pm
Yeah, it looks like the file attached to it is just an XML file, so maybe something went wrong when saving the file? I'd recommend zipping up both the xml file and the python script, then putting the zip file in the File Library entry.
