Please check the Indigo log and see what plugin it's complaining about. You probably need to get rid of it.Ksullivan wrote:That got it I'm using it to control the volume on the russound plugin and works a treat. Now to try Siri
Thanks Joe
Masquerade Plugin
- FlyingDiver
Re: Masquerade Plugin
Hi Joe
One observation is that when setting the device through the russound plugin the dimmer matches well i.e 30 on the russound plugin = 100% on the dimmer (0=min 30=max) but when you set the dimmer to 100% then the volume tries to go to 100 (nearly blows my speakers) any ideas?
Keith
Keith
- FlyingDiver
The scaling logic might need some work. You set the low limit to 0 and the high limit to 30? So 50% on the dimmer should give you 15 in the Russound, and 100 on the dimmer should be 30. If that's not happening, I need to look at that again.Ksullivan wrote:Hi Joe
It works fine controlling it from the device it shows the correct scaling bur when you set the dimmer it has a little fit.
Using the device
When setting from the dimmer it doesn't scale based on the config figures
Hope this helps
Masquerade Debug Russound Zone 3, a masqueraded device, has been updated: Zone 3 (22).
Masquerade Debug lowLimit = 0.000000, highLimit = 30.000000, reverse = False, scaled = 73.333333
Using the dimmer
Masquerade Debug actionControlDevice: deviceAction = SetBrightness
Masquerade Debug actionControlDevice: actionValue = 64
Masquerade Debug actionControlDevice: devicePlugin = com.jottoawa.indigoplugin.russound
Masquerade Debug actionControlDevice: baseDevice = 651849078
Masquerade Debug actionControlDevice: masqAction = actionSetZoneVolume
Masquerade Debug actionControlDevice: masqValueField = setting
Masquerade Debug actionControlDevice: masqState = Volume
Masquerade Debug actionControlDevice: lowLimit = 0
Masquerade Debug actionControlDevice: highLimit = 30
Masquerade Debug actionControlDevice: reverse = False
Masquerade Debug actionControlDevice: "Zone 3" Set Brightness to 64
Hope this helps
- FlyingDiver
I just looked at the code again. I forgot to implement the scaling going that direction.
I should have something later tonight.
Thanks Joe
- FlyingDiver
v0.0.5 available now: https://github.com/FlyingDiver/Indigo-M ... tag/v0.0.5
Joe,
This looks like a fascinating little plugin that could really be useful in a number of scenarios. My particular use case: a Leviton z-wave fan controller without a proper device definition. In my situation, these particular fan controllers (Leviton VRF01-1LZ) display as dimmers when they should be Off-Low-Med-High devices. Would imagine there are others who have the same issue...
Thanks and keep up the great work!
Hi Joe
Updated this morning and now get this error
- FlyingDiver
Would it be possible for you to post the text from the Indigo client event log, not screen shots of Indigo Touch? I don't think I'm getting the entire context of the errors.
And can you explain exactly what you were doing to get that error?
I'm also scratching my head trying to figure out why it's generating that specific error. I would only expect to see that on a hex conversion.
Hi Joe
Control from russound plugin changing fro Vol 20 - Vol 22
Dimmer changes and move to 73
Now if i amend the the slider on the dimmer from 73 to 53
System throws a fit and goes straight to 100
Now if i change the slider to 27 it tries to set the volume to 8 but i get this error (might need to be 08?)
Now if i set the slider to 35 I get this
Masquerade Debug scaleBaseToMasq: lowLimit = 0, highLimit = 30, reverse = False, input = 22, scaled = 73
Masquerade Debug dimmerDeviceUpdate: Russound Zone 1 (22) --> Zone 1 (73)
Masquerade Debug scaleMasqToBase: lowLimit = 0, highLimit = 30, reverse = False, input = 53, scaled = 15
Masquerade Debug actionControlDevice: "Zone 1" Set Brightness to 15
Masquerade Warning Input value for Zone 1 is higher than expected: 42
Masquerade Debug scaleBaseToMasq: lowLimit = 0, highLimit = 30, reverse = False, input = 30, scaled = 100
Masquerade Debug dimmerDeviceUpdate: Russound Zone 1 (42) --> Zone 1 (100)
Masquerade Debug scaleMasqToBase: lowLimit = 0, highLimit = 30, reverse = False, input = 27, scaled = 8
Masquerade Debug actionControlDevice: "Zone 1" Set Brightness to 8
Masquerade Error Error in plugin execution ExecuteAction:
File "plugin.py", line 255, in actionControlDevice
TypeError: Odd-length string
Masquerade Debug scaleMasqToBase: lowLimit = 0, highLimit = 30, reverse = False, input = 35, scaled = 10
Masquerade Debug actionControlDevice: "Zone 1" Set Brightness to 10
Masquerade Warning Input value for Zone 1 is higher than expected: 32
Masquerade Debug dimmerDeviceUpdate: Russound Zone 1 (32) --> Zone 1 (100)- FlyingDiver
You're using the latest version (0.0.5)? Delete your Masquerade device (Zone 1) and create it again. And then post an image of the device config dialog when you're done. I'm just not getting the same results you are.
Dec 14, 2016, 2:05:07 PM 12/14
Action Group Maquerade Testing
Example Device - Relay/Dimmer sent "Masquerade Test Dimmer" set backlight brightness to 22
Masquerade Debug dimmerDeviceUpdate: Masquerade Test Dimmer (22) --> Masquerade Dimmer (73)
Dec 14, 2016, 2:05:53 PM 12/14
Masquerade Debug actionControlDevice: "Masquerade Dimmer" Set Brightness to 15
Example Device - Relay/Dimmer sent "Masquerade Test Dimmer" set backlight brightness to 15
Masquerade Debug scaleBaseToMasq: lowLimit = 0, highLimit = 30, reverse = False, input = 15, scaled = 50
Masquerade Debug dimmerDeviceUpdate: Masquerade Test Dimmer (15) --> Masquerade Dimmer (50)
Dec 14, 2016, 2:08:33 PM 12/14
Masquerade Debug actionControlDevice: "Masquerade Dimmer" Set Brightness to 8
Example Device - Relay/Dimmer sent "Masquerade Test Dimmer" set backlight brightness to 8
Masquerade Debug scaleBaseToMasq: lowLimit = 0, highLimit = 30, reverse = False, input = 8, scaled = 26
Masquerade Debug dimmerDeviceUpdate: Masquerade Test Dimmer (8) --> Masquerade Dimmer (26)
Dec 14, 2016, 2:08:55 PM 12/14
Masquerade Debug actionControlDevice: "Masquerade Dimmer" Set Brightness to 10
Example Device - Relay/Dimmer sent "Masquerade Test Dimmer" set backlight brightness to 10
Masquerade Debug scaleBaseToMasq: lowLimit = 0, highLimit = 30, reverse = False, input = 10, scaled = 33
Masquerade Debug dimmerDeviceUpdate: Masquerade Test Dimmer (10) --> Masquerade Dimmer (33)
Config
Here's the log;
Masquerade Debug scaleMasqToBase: lowLimit = 0, highLimit = 30, reverse = False, input = 52, scaled = 15
Masquerade Debug actionControlDevice: "Masquerade Zone 1" Set Brightness to 15
Masquerade Warning Input value for Masquerade Zone 1 is higher than expected: 42
Masquerade Debug dimmerDeviceUpdate: Russound Zone 1 (42) --> Masquerade Zone 1 (100)
Masquerade Debug scaleMasqToBase: lowLimit = 0, highLimit = 30, reverse = False, input = 62, scaled = 18
Masquerade Debug actionControlDevice: "Masquerade Zone 1" Set Brightness to 18
Masquerade Warning Input value for Masquerade Zone 1 is higher than expected: 48
Masquerade Debug dimmerDeviceUpdate: Russound Zone 1 (48) --> Masquerade Zone 1 (100)
Masquerade Debug scaleMasqToBase: lowLimit = 0, highLimit = 30, reverse = False, input = 38, scaled = 11
Masquerade Debug actionControlDevice: "Masquerade Zone 1" Set Brightness to 11
Masquerade Warning Input value for Masquerade Zone 1 is higher than expected: 34
Masquerade Debug dimmerDeviceUpdate: Russound Zone 1 (34) --> Masquerade Zone 1 (100)
