openssl upgrade (for TLS 1.2)
Thu Dec 01, 2016 5:51 pm
alistair offline
I spent some time searching the forums - but didn't come up with much other than Perry The Cynic spending a bunch of time back on Python 2.5.
Has anyone worked out how to upgrade OpenSSL (w/ Indigo 7) such that it doesn't use the OS X crappy old 0.9 version of OpenSSL?
Fri Dec 02, 2016 2:16 am
MarcoGT offline
Re: openssl upgrade (for TLS 1.2)
How did you try the upgrade?
You can also take the sources and compile them for your platform
Fri Dec 30, 2016 12:37 pm
alistair offline
I tried using homebrew to update openssl and the underlying Python version. It works fine, but I then get some odd errors from Indigo which is, I suspect, due to Indigo using a mix of both the Apple and newer Python versions.
Anyone any ideas?
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/plugin_base.py", line 26, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serial/__init__.py", line 13, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/IndigoPluginHost.app/Contents/PlugIns/serial/serialutil.py", line 10, in <module>
  File "/usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/io.py", line 51, in <module>
ImportError: dlopen(/usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so, 2): Symbol not found: __PyCodecInfo_GetIncrementalDecoder
  Referenced from: /usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so
  Expected in: flat namespace
 in /usr/local/Cellar/python/2.7.13/Frameworks/Python.framework/Versions/2.7/lib/python2.7/lib-dynload/_io.so
Sat Feb 04, 2017 4:32 pm
alistair offline
I'm still trying to work this one out. Plugins running inside Indigo use the old version of openssl, which means I can't use TLS 1.2 required connections.
I suspect that IndigoPluginHost is ignoring the system path somewhere, and using the "inbuilt" python instead of the one in the path.
Anyone any ideas? Apple's 0.9.x version of openssl is terrible :(
Sat Feb 04, 2017 7:24 pm
Indigo 6 uses Python 2.6, Indigo 7 uses Python 2.7.
Sat Feb 04, 2017 7:26 pm
alistair offline
Hi Jay
I get that it uses Python 2.7, but it seems to forcibly use the (broken - old openssl) *system* Python 2.7, instead of the path default (which is also 2.7, but managed by homebrew, and has a non-ancient version of openssl).
Any thoughts on how an upgraded version of openssl can be made available to plugins?
Sun Feb 05, 2017 4:28 pm
We use the Apple-supplied version of Python. If homebrew doesn't install in a location that's known by the built-in Python install, then it won't work. There is probably some way to install it so that it does use the built-in interpreter, but I don't know what it is.
We don't support using any other Python because debugging becomes a nightmare and because we use libraries that are compiled against the built-in installation.
Mon Apr 24, 2017 7:12 pm
Bollar offline
I have found this workaround will get python scripts within Indigo to use TLS 1.2. I do not know if it breaks anything else.
https://clburlison.com/python2-and-tls/
