Device Extension errors
Sun Nov 27, 2016 11:13 am
Getting a fair number of these:
2016-11-22 23:02:42.602   EPS - Device Extensions Error   Error in plugin execution ExecuteAction:
  File "plugin.py", line 414, in actionControlDimmerRelay
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 154, in urlopen
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 431, in open
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 449, in _open
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 409, in _call_chain
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 1240, in https_open
  File "/System/Library/Frameworks/Python.framework/Versions/2.7/lib/python2.7/urllib2.py", line 1197, in do_open
URLError: <urlopen error EOF occurred in violation of protocol (_ssl.c:590)>
and this is odd because I have no irrigation system:
2016-11-22 23:01:51.719   EPS - Device Extensions Error   Error in plugin execution runConcurrentThread:
  File "plugin.py", line 395, in runConcurrentThread
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Device Extensions.indigoPlugin/Contents/Server Plugin/eps/SmartIrrigation.py", line 252, in irrigationTimerTick
StandardError: ServerCommunicationError -- timeout waiting for response
Sun Nov 27, 2016 11:15 am
Colorado4Wheeler offline
Re: Device Extension errors
Thanks for posting, I've been a bit out of the mix for the past few weeks due to a big project but I'm going to start getting some of this stuff done in the next week, I'll add this to the list!
Wed Nov 30, 2016 11:13 am
Also seeing this pop up now and again:
  File "plugin.py", line 697, in actionControlDimmerRelay
  File "plugin.py", line 658, in urlDeviceAction
KeyError: key url not found in dict
Thu Dec 15, 2016 10:22 pm
and
Fri Dec 16, 2016 7:13 am
Thanks for reporting this, as soon as I can get Homebridge Buddy updated I can devote more time to getting this and my other plugins updated.
Sun Sep 17, 2017 8:05 pm
davvi offline
Everything's been working fine for months, but recently I keep getting this error:
   EPS - Device Extensions Error   Error in plugin execution InitializeMain:
  File "plugin.py", line 24, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Device Extensions.indigoPlugin/Contents/Server Plugin/bs4/__init__.py", line 30, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Device Extensions.indigoPlugin/Contents/Server Plugin/bs4/builder/__init__.py", line 314, in <module>
  File "/Library/Application Support/Perceptive Automation/Indigo 7/Plugins/EPS Device Extensions.indigoPlugin/Contents/Server Plugin/bs4/builder/_html5lib.py", line 70, in <module>
AttributeError: 'module' object has no attribute '_base'
Reloading, reinstalling, disabling/enabling... nothing gets rid of the error. Any ideas as to cause? Thank you.
Sat Dec 02, 2017 4:00 pm
Colly offline
Hi C4W,
Getting this error in the log, I ended up disabling the plugin sometime back and forgot to re-enable and now getting these errors. I deleted the plugin, restarted the server and still having issues.
Any help appreciated.
  File "plugin.py", line 590, in runConcurrentThread
  File "plugin.py", line 474, in forceUpdate
  File "plugin.py", line 486, in calcMinutes
TypeError: debugLog() got an unexpected keyword argument 'isError'
   EPS - Device Extensions Error   plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
Mon Jan 08, 2018 1:50 pm
Getting ready to release a new version and was double checking on any possible outstanding issues and read this. I don't think you are on the latest version because several of those functions don't exist any longer and that 'isError' would have been tied to the old Indigo style of logging which Device Extensions hasn't used for a while. Anyway, check for todays release and try that.
Fri Jan 12, 2018 1:33 pm
rehafer offline
Updated to 2.0.3 and I now get:
EPS - Device Extensions Error Exception in plugin.onAfter_runConcurrentThread line 103: 'key epsdeth not found in dict'
CODE: for devId in eps.cache.pluginItems["epsdeth"]:
repeated every few seconds
Any thoughts?
Fri Jan 12, 2018 1:35 pm
That was fixed in 2.0.4, available from Git as it's not yet been published on the Plugin Store.
Fri Jan 12, 2018 1:40 pm
I just put 2.0.4 in the plugin store since it does fix this bug and the current plugin store version HAS the bug :shock: :roll:
Fri Jan 12, 2018 4:11 pm
rehafer offline
That did the trick, thanks
Thu Jan 18, 2018 6:19 am
MarcoGT offline
I just restarted Indigo Server to modify the log option of piBeacon and since then I have following error:
Exception in plug.nonpluginDeviceUpdated line 439: 'ascii' codec can't encode character  u'\xe0' in position 9: ordinal not in range(128)
CODE: self.logger.threaddebug("Non plugin device '{0}' has been updated".format(newDev.name))
I am using the plugin just for an Action Group to speak weather in the morning, not more.
Thu Jan 18, 2018 9:11 am
That is one of your device names, not a Device Extension device, that has that character (I believe it is the small letter 'a' with a grave) in it. I could be wrong about the symbol though, but it is definitely a non-standard symbol whatever it is.
Thu Jan 18, 2018 9:20 am
MarcoGT offline
You mean something that has nothing to do with Device Extension Plugin? And then why is the plugin complaining about it?
