rapamatic wrote:I keep getting the following error message, about a pickle? Any ideas?
Had to research that one a bit as I hadn't seen it before. Your install is crashing when we try to import matplotlib.pyplot. Please try the following steps:
(1) From the Indigo Scripting Shell, please try the following command:
- Code: Select all
import matplotlib.pyplot as plt
I suspect that it will generate the same error. Please let me know if that's not the case.
(2) Try rebooting the machine running the Indigo Server.
It seems that there can sometimes be issues with Matplotlib dependencies on Macs that don't generate the proper traceback and instead provide an insecure pickle error. My source;
https://github.com/matplotlib/matplotlib/issues/5314/- Issue #26083: Workaround a subprocess bug that raises an incorrect
"ValueError: insecure string pickle" exception instead of the actual
exception on some platforms such as Mac OS X when an exception raised
in the forked child process prior to the exec() was large enough that
it overflowed the internal errpipe_read pipe buffer.
Several users in that thread suggested that a reboot solved their issue. Please let me know how it goes.
