- Code: Select all
sudo easy_install-2.6 pip
autolog wrote:Looks like you need to install pip2.6, try this:
- Code: Select all
7. jun. 2016, 13.15.14
Verisure Error Error in plugin execution runConcurrentThread:
File "plugin.py", line 108, in runConcurrentThread
File "plugin.py", line 191, in _refreshAlarmStatesFromVerisure
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe5' in position 1: ordinal not in range(128)
Verisure Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
File "plugin.py", line 193, in _refreshAlarmStatesFromVerisure
haavarda wrote:Hi,
Have an error that is causing the plugin to dump a lot of errors in the log. Seams to be related to unicode?
Any idea?
Håvard
- Code: Select all
17. jun. 2016, 16.56.26
Indigo Cocoa client authenticated (192.168.1.101)
Enabling plugin "Verisure 0.3.2"
Starting plugin "Verisure 0.3.2" (pid 56351)
Started plugin "Verisure 0.3.2"
Verisure Debug startup called
Verisure Debug Debug is set to: False
Verisure Checking for updates...
Verisure No updates are available
17. jun. 2016, 16.58.08
Action Group Verisure - enable AutoLock & Lock
Verisure Updated autolock for 'Doorman' to True
Schedule _delayed_action_58
Verisure Updated Lock State: LOCKED
17. jun. 2016, 17.00.54
Verisure Debuging is set to: True
Verisure Debuging is set to: False
17. jun. 2016, 17.02.48
Indigo Cocoa client connected
Indigo Cocoa client disconnected
UnicodeEncodeError: 'ascii' codec can't encode character u'\xe9' in position 4: ordinal not in range(128)
But the lock status is displayed as "Låst"(locked). I can't change this as it is verisures state. Could the errors be related to this?
haavarda wrote:I tried deleting the device and recreating it. So far I have not seen the error again. So it have something to do with something I have done on the verisure pages. Thanks for a great plugin.
Håvard
jens wrote:Hello have upgrading to Indigo 7 and then the plugin dount work any more, please help
//Jens
Users browsing this forum: No registered users and 26 guests
