Onkyo Network Remote - Introduction & Installation
Tue Jul 22, 2014 10:15 pm
RogueProeliator offline
Introduction
This Indigo plugin allows Indigo to act as a remote display and/or control for a network-connected Onkyo Receiver. All commands/buttons found on the standard remote can be sent to the receiver as well as many additional commands not readily available for direct access (normally requiring menu navigation). The status of many different aspects of the receiver is available via Indigo Device states.
Links
Plugin Store | Full Documentation | GitHub Repo | Help Forum | Indigo 6 Plugin
Tue Jul 22, 2014 10:17 pm
Re: Onkyo Network Remote - Introduction & Installation
v0.5.9 Initial BETA Release
This first version posted, v0.5.9 should be considered a BETA release -- it has only been tested on one Onkyo receiver model thus far and, though working for me, is likely to have a few bugs or missing features. Please post any issue or enhancement suggestions that you would like!
Sun Jul 27, 2014 9:33 am
v0.6.9 BETA Release
The following changes were made to v0.6.9, which is now posted (same download link in original post):
  • Fixed bug which prevented the list of input devices showing up for selection in the initial Device Configuration dialog (when creating and setting up a new Onkyo device).
Wed Oct 01, 2014 10:24 pm
v1.0.10 Release
The following changes were made to v1.0.10, which is now posted (same download link in original post):
  • Better reconnection attempts and logic for dropped connections
  • Added ability to specify a repeat count on volume up/down actions, thus allowing "large change" buttons on control pages
  • Fixed the isPoweredOn to show "False" whenever the receiver is in Standby mode
Tue Nov 04, 2014 12:45 pm
v1.1.12 Release
The following changes were made to v1.1.12, which is now posted (same download link in original post):
  • Added the ability to select which state is shown in the Devices list (and on mobile clients such as Indigo Touch and HousePad); you can select the display in the Device Configuration dialog for the receiver.
  • Improved the response time when issuing multiple commands in a short amount of time.
  • Added a new device type - a "Virtual Volume Controller". This device is attached to a standard receiver device and allows controlling the volume via a dimmer control. This allows it to be directly controlled via a popup in remote clients such as Indigo Touch, HousePad or a web browser.
Wed Mar 04, 2015 12:03 am
v1.3.14 Release
The following changes were made to v1.3.14, which is now posted (same download link in original post):
  • Added the ability to send any arbitrary command to the Onkyo receiver (via the Plugins menu)
  • Added a graphical interface to the update check from the Plugins menu
  • Added an event that fires when an update has been detected for the plugin
Sun Apr 26, 2015 9:20 pm
v1.5.15 Release
The following changes were made to v1.5.15, which is now posted (same download link in original post):
  • Added Zone 2 Power state and control
  • Added Zone 2 Input state and control
  • Added Zone 2 Volume state and control
Fri Jun 05, 2015 11:09 pm
v1.6.15 Release
The following changes were made to v1.6.15, which is now posted (same download link in original post):
  • Added Zone 2 support for Virtual Volume Controller Device
  • Added Toggle ability (for muting/un-muting) to the Volume Controller Device
  • Fixed a bug that could temporarily cause Virtual Volume Controller to display incorrect status
  • Change isPoweredOn to be False when in Standby mode
  • Significantly improved the efficiency of communications with the Onkyo device
Fri Dec 18, 2015 9:50 pm
v1.7.18 Release
The following changes were made to v1.7.18, which is now posted (same download link in original post):
  • Adds support for Unicode device names
  • Adds support for receivers returning slightly different formated volume returns
  • Sets error state on the server when connection times out / fails
  • Adds additional debug logging
Sun Feb 07, 2016 10:42 pm
v1.8.19 Release
The following changes were made to v1.8.19, which is now posted (same download link in original post):
  • Fixes bug for receivers returning slightly different formatted volume returns
  • Allows installation of plugin when download has been renamed
Sat Apr 23, 2016 8:54 pm
v2.0.0 Release
The following changes were made to v2.0.0, which is now posted; note that the download link has changed and has been updated in the original post. It may be downloaded here. Future updates may be downloaded directly via the "Check for Updates" menu option.
  • Adds new statuses for network streaming - artist, album, title and status
  • Adds status for tracking the current tuner frequency
  • Adds action for directly tuning to a station
  • Changes updater to use GitHub (thanks jheddings)
  • Logging level changes as per Indigo's recommendations to eliminate extraneous logging from 3rd party libraries
Sat Nov 12, 2016 10:50 pm
v2.1.1 Release
The following changes were made to v2.1.1, which is now posted; note that the download link has changed and has been updated in the original post. It may be downloaded here. Future updates may be downloaded directly via the "Check for Updates" menu option.
  • Updated to full Indigo 7 support
  • Indigo 7 is required for this and all future plugin versions
Fri Jun 14, 2019 11:18 pm
v2.1.3 Release
The following changes were made to v2.1.3, which is now posted; it may be downloaded via the plugin store or from the menu options inside the Indigo Client. Note, I believe at least a couple of people were running this version via a pre-release to fix specific issues below, nothing significant has changed from that and no need to update.
  • Fixed tuning issue with direct tune to AM stations
  • Fixed issue reading the currently tuned radio station
  • Added property on receivers to adjust the volume display - receivers may send base 10 or base 16 numerical values
  • Added input source of 18 as reported as a valid input in the forum
Thu Nov 19, 2020 11:08 pm
v2.1.4 Release
  • Updated to Indigo 7.3+ standards
  • Unified plugin UI across all RogueProeliator plugins
  • Added support for STRMBOX input
  • Now requires Indigo 7.3+ (old versions will remain available for previous versions)
