- Code: Select all
int val = analogRead(pin);
if (pin ==1){ val=1023 - val}
#if defined(DEBUG)
Serial.print("command = A-read - "); Serial.println(val);
#endif
out+="rd:A"+String(pin)+'='+String(val)+'&';
return;
in the analog pin read section
#if defined(DEBUG)
#endif
return;
Arduino: 1.6.11 (Windows 7), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 9600, 4M (3M SPIFFS)"
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Yasmin\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Yasmin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Yasmin\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=9600,FlashSize=4M3M -ide-version=10611 -build-path C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\Yasmin\Desktop\indigo_Wlan_290916_final_ohne_Ethernet\indigo_Wlan_290916_final_ohne_Ethernet.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Yasmin\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Yasmin\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\Yasmin\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=9600,FlashSize=4M3M -ide-version=10611 -build-path C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mkspiffs.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.esptool.path=C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\Users\Yasmin\Desktop\indigo_Wlan_290916_final_ohne_Ethernet\indigo_Wlan_290916_final_ohne_Ethernet.ino
Using board 'nodemcuv2' from platform in folder: C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiClient.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiClientSecure.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiServer.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiUdp.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "C:\Users\Yasmin\Documents\Arduino\libraries\OneWire\OneWire.cpp" -o "nul"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature\DallasTemperature.cpp" -o "nul"
Generating function prototypes...
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino10/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
Sketch wird kompiliert...
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10611 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-IC:\Users\Yasmin\Documents\Arduino\libraries\OneWire" "-IC:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp" -o "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp.o"
Compiling libraries...
Compiling library "ESP8266WiFi"
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiClient.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiClientSecure.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiServer.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiUdp.cpp.o
Compiling library "OneWire"
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\OneWire\OneWire.cpp.o
Compiling library "DallasTemperature"
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\DallasTemperature\DallasTemperature.cpp.o
Compiling core...
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cont.S.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cont_util.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_eboot_command.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_flash_utils.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_i2s.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_noniso.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_phy.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_postmortem.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_si2c.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_timer.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_analog.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_digital.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_pulse.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_pwm.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_shift.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\heap.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libc_replacements.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\time.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\uart.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libb64\cdecode.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libb64\cencode.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_cache.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_check.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_gc.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_hydrogen.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_nucleus.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\umm_malloc\umm_malloc.c.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Esp.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\FS.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\HardwareSerial.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\IPAddress.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\MD5Builder.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Print.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Schedule.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Stream.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\StreamString.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Tone.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Updater.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\WMath.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\WString.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\abi.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\base64.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cbuf.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_main.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\debug.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\pgmspace.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs_api.cpp.o
Zuvor kompilierte Datei wird verwendet: C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs_hal.cpp.o
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cont.S.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cont_util.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_eboot_command.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_flash_utils.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_i2s.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_noniso.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_phy.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_postmortem.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_si2c.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_timer.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_analog.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_digital.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_pulse.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_pwm.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_wiring_shift.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\heap.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libc_replacements.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\time.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\uart.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libb64\cdecode.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\libb64\cencode.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_cache.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_check.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_gc.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_hydrogen.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs\spiffs_nucleus.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\umm_malloc\umm_malloc.c.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Esp.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\FS.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\HardwareSerial.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\IPAddress.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\MD5Builder.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Print.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Schedule.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Stream.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\StreamString.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Tone.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\Updater.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\WMath.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\WString.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\abi.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\base64.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\cbuf.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\core_esp8266_main.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\debug.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\pgmspace.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs_api.cpp.o"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-ar" cru "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\core\spiffs_hal.cpp.o"
Linking everything together...
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -g -w -Os -nostdlib -Wl,--no-check-sections -u call_user_start -Wl,-static "-LC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lib" "-LC:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/ld" "-Teagle.flash.4m.ld" -Wl,--gc-sections -Wl,-wrap,system_restart_local -Wl,-wrap,register_chipv6_phy -o "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.elf" -Wl,--start-group "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\sketch\indigo_Wlan_290916_final_ohne_Ethernet.ino.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFi.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiAP.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiGeneric.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiMulti.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiSTA.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\ESP8266WiFiScan.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiClient.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiClientSecure.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiServer.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\ESP8266WiFi\WiFiUdp.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\OneWire\OneWire.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp\libraries\DallasTemperature\DallasTemperature.cpp.o" "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/arduino.ar" -lm -lgcc -lhal -lphy -lpp -lnet80211 -lwpa -lcrypto -lmain -lwps -laxtls -lsmartconfig -lmesh -lwpa2 -llwip_gcc -lstdc++ -Wl,--end-group "-LC:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp"
"C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe" -eo "C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/bootloaders/eboot/eboot.elf" -bo "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.bin" -bm dio -bf 40 -bz 4M -bs .text -bp 4096 -ec -eo "C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.elf" -bs .irom0.text -bs .text -bs .data -bs .rodata -bc -ec
Bibliothek ESP8266WiFi in Version 1.0 im Ordner: C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi wird verwendet
Bibliothek OneWire in Version 2.3.2 im Ordner: C:\Users\Yasmin\Documents\Arduino\libraries\OneWire wird verwendet
Bibliothek DallasTemperature in Version 3.7.6 im Ordner: C:\Users\Yasmin\Documents\Arduino\libraries\DallasTemperature wird verwendet
Der Sketch verwendet 239.729 Bytes (22%) des Programmspeicherplatzes. Das Maximum sind 1.044.464 Bytes.
Globale Variablen verwenden 33.396 Bytes (40%) des dynamischen Speichers, 48.524 Bytes f¸r lokale Variablen verbleiben. Das Maximum sind 81.920 Bytes.
C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe -vv -cd nodemcu -cb 9600 -cp COM3 -ca 0x00000 -cf C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to nodemcu
setting baudrate from 115200 to 9600
setting port from COM1 to COM3
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
espcomm_send_command: receiving 2 bytes of data
Uploading 243872 bytes from C:\Users\Yasmin\AppData\Local\Temp\build4a90017635be01b4a59dc07b4af8e2ac.tmp/indigo_Wlan_290916_final_ohne_Ethernet.ino.bin to flash at 0x00000000
erasing flash
size: 03b8a0 address: 000000
first_sector_index: 0
total_sector_count: 60
head_sector_count: 16
adjusted_sector_count: 44
erase_size: 02c000
setting serial port timeouts to 15000 ms
writing flash
wrote 992, requested 1072
error: failed sending 1072 bytes
. wrote 992, requested 1044
error: failed sending 1044 bytes
. wrote 992, requested 1040
error: failed sending 1040 bytes
. wrote 992, requested 1069
error: failed sending 1069 bytes
. wrote 992, requested 1073
error: failed sending 1073 bytes
. wrote 992, requested 1064
error: failed sending 1064 bytes
read 0, requested 1
warning: espcomm_send_command: didn't receive command response
warning: espcomm_send_command(FLASH_DOWNLOAD_DATA) failed
warning: espcomm_send_command: wrong direction/command: 0x01 0x03, expected 0x01 0x04
closing bootloader
flush start
flush complete
error: espcomm_upload_mem failed
kw123 wrote:try different baud rate (not 9600.. i believe the esp default is 1xxxxx > 100k
Der Sketch verwendet 237.041 Bytes (22%) des Programmspeicherplatzes. Das Maximum sind 1.044.464 Bytes.
Globale Variablen verwenden 33.072 Bytes (40%) des dynamischen Speichers, 48.848 Bytes f¸r lokale Variablen verbleiben. Das Maximum sind 81.920 Bytes.
C:\Users\Yasmin\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe -vv -cd nodemcu -cb 115200 -cp COM3 -ca 0x00000 -cf C:\Users\Yasmin\AppData\Local\Temp\build665457cce46db348b64e97e2e10523e7.tmp/NodeMCU_MQTT_DS18B20.ino.bin
setting baudrate from 115200 to 115200
espcomm_upload_file
espcomm_upload_mem
opening bootloader
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
Uploading 241184 bytes from C:\Users\Yasmin\AppData\Local\Temp\build665457cce46db348b64e97e2e10523e7.tmp/NodeMCU_MQTT_DS18B20.ino.bin to flash at 0x00000000
erasing flash
size: 03ae20 address: 000000
total_sector_count: 59
adjusted_sector_count: 43
erase_size: 02b000
read 0, requested 1
warning: espcomm_send_command(FLASH_DOWNLOAD_BEGIN) failed
closing bootloader
flush start
flush complete
Beim Hochladen des Sketches ist ein Fehler aufgetreten
kw123 wrote:Will looks at the error later.
kw123 wrote:Yassi, remembering your windows setup.. the setup need to get tuned . either move the arduino IDE to the MAC or have a better interface MAC--> WINDOWS where all keys work to see what the issues are .
BUT I do remember that the NODEMCU had problems with the chip they used for USB . I needed to down load a version from some wild Chinese website and it crashed my mac ..
I am not sure if you want to spend a lot more time on the NODEMCU. There are many alternatives with better USB integration and they work on the MAC too.
Sam wrote:Hi,
I have a problem with my outputs via two relay cards (2x8 relays from the pin 34-49) where the relays are activated with low signal from the Arduino Mega Digital pins. The problem is when Arduino start or restart to pull all the relays for about 1 second and then return to normal. How can I avoid this during start up?
The voltage to the relay coils are fed from an external 5VDC 3A.
Thanks in advance.
/Sam
