- Posted on
Tue Oct 04, 2016 5:30 am
matt (support)
offline
- Site Admin
I suspect it is the refreshing images causing the problem, even though that shouldn't be the case. Indigo doesn't cache/save those, but it sounds like there is a memory leak either in Indigo Touch or iOS. What version of Indigo Touch are you running? And what version of iOS and iPad do you have?
That said, that wouldn't explain why the app was still showing 3GB of usage after you deleted and reinstalled it. If you do that, and haven't launched it or opened any Control Pages yet, then it should be well under 1GB as Jay mentioned. I've had mine installed for months and it is showing 1.62 GB (and I use refreshing images and SecuritySpy).
