the dots showing up if .....
fixed with version .4: http://forums.indigodomo.com/viewtopic.php?f=165&t=15884
as for the plot sometimes not complete.. that is the (part of) the timing I was talking about.
The SQL jobs run and I need to sync the plotting to when they are finished. As these are independent for MATPlot(*). It sometimes can happen that the sql job is just running while MATPLOT is trying to plot and read the SQL output.
as matplot requires python 2.7 and for indigo 6 only python 2.6 works, the matplot process needs to be running outside indigo. This is done with something like "python2.7 matplotprogram.py" from within the plugin, Then the matplotlib job is left alone and does its thing until restart .. . It will need to check if SQL job is finished before reading the sql output.. That is what I am working on.
