Weathersnoop plugin not working with WS 3.1.5 pre-flight
Fri Aug 12, 2016 11:35 am
rjeffl offline
Just changed over from Weathersnoop 3.1.4 to 3.1.5 pre-flight 1028.
Seems that the indigo plugin breaks with the new json data format?
Here is the error posted in the log...
WeatherSnoop Error Couldn't get information for site - check WeatherSnoop for issues: /EF1FAAD0-5FEB-4131-B84B-BA08625EAECD.json
Tried restarting server, disabling and re-enabling plugin (v2.0.10).
No luck.
Running Indigo 6.1.10 on the same machine.
When I try to add a weathersnoop device, Indigo can find the server but complains that it can't find an agent.
Any ideas?
Thanks.
Jeff
Fri Aug 12, 2016 2:02 pm
Re: Weathersnoop plugin not working with WS 3.1.5 pre-flight
I just talked to Boisy and he did make a change to his API. For the moment, you're going to want to avoid 3.1.5 until I can find some time to look into it. We're heads down trying to get Indigo 7 ready to ship so it may not happen very quickly.
Fri Aug 12, 2016 2:40 pm
boisy offline
Sorry about this guys. 3.1.5 pre-flight fixes an issue, which unfortunately breaks Indigo's WeatherSnoop plug-in. Please stay on 3.1.4 until we can get this resolved.
Fri Aug 12, 2016 2:46 pm
keifer1 offline
" We're heads down trying to get Indigo 7 ready to ship."
:D :D :D :D SAY WHAT! :D :D :D :D
Don't worry - I can just download mine you don't have to ship. But I appreciate the thought. Email me the link.
Computer Keith
Mt Pleasant SC - Charleston
Indi-Go -Go-Go
Sun Aug 14, 2016 8:54 am
boisy offline
Just an update on this:
I've updated pre-flight build 1029 so that you can "flip a switch" to preserve the old behavior. To do this, go to the Terminal.app and type:
defaults write com.tee-boy.WeatherSnoop3 Indigo -bool true
This turns on the old behavior of embedding the entire local URL into the XML/JSON responses and will allow the WeatherSnoop 3 plug-in for Indigo to continue to work.
Note that this is a work-around until I can get with Jay to revisit the WeatherSnoop 3 plug-in. Engaging this switch also means that using the WeatherSnoop iOS app outside of your local network will fail. Because of this, the switch is by default, off. I also expect to remove it as soon as the WeatherSnoop 3 plug-in for Indigo can be updated.
Sun Aug 14, 2016 5:02 pm
rjeffl offline
Thanks Boisy.
We'll check it out.
Jeff
Tue Aug 16, 2016 5:25 pm
Gwil_Evans offline
I entered the suggested string in Terminal, but to no avail.
I wonder if it is possible to download WS 3.1.4 to replace 3.1.5 until this is fixed?
Mon Aug 29, 2016 3:13 pm
boisy offline
Jay sent me an updated Indigo plug-in which fixes the issue. I'm not sure if it's available for download yet, however. Jay, is it posted?
Mon Aug 29, 2016 4:52 pm
It'll be in the next Indigo 6 build.
Mon Sep 26, 2016 3:15 pm
Indigo 6.1.11 is now available for download and it addresses this API change.
Sat Oct 08, 2016 12:20 pm
cjp767 offline
I am still seeing regular crashing of the Indigo client (not server) and/or the Weathersnoop application while running the Weathersnoop plugin. When I disable the Weathersnoop plugin, no crashing occurs. Apparently they do not work or play well with each other. And this may, of course, be caused by my early upgrade to Mac OS 10.12.
Weathersnoop 3.1.5
Indigo 6.1.11
----> Mac OS 10.12
on a 2010 Mac Pro
Tue Oct 11, 2016 9:55 am
Send one of the crash report files to support@indigodomo.com and reference this thread. A client crash would seem to be very unlikely to be caused by a plugin, but the crash report will give us more information.
