LCD Creator - Room-O-Matic or ANY Control Page
Mon Jun 06, 2016 2:16 am
Colorado4Wheeler offline
NOTICE
The original post, including information, screen shots, installation & documentation has been moved to THIS OTHER THREAD.
The rest of this topic has been left intact.
Mon Jun 06, 2016 9:00 am
keifer1 offline
Re: New Plugin: LCD Creator - Room-O-Matic or ANY Control Pa
WOW,
Computer Keith
Mt Pleasant SC - Charleston
Indi-Go -Go-Go
Mon Jun 06, 2016 9:14 am
keifer1 wrote:
WOW,
My wife made a similar comment when I finally came to bed at 3:30am after uploading this early this morning :D.
Tue Jun 07, 2016 9:46 am
Neat plugin – thanks for sharing!
Tue Jun 07, 2016 10:33 am
Updated today, see original post for release notes, minor typo was fixed.
Thu Jun 09, 2016 12:56 pm
Londonmark offline
I have this working for Weather Underground and it's great, but the device I have created for my Tado thermostat doesn't seem to populate with any values - when I check in Device Details, all the fields are empty. I've switched on debugging, but nothing's showing. Any thoughts?
M
Thu Jun 09, 2016 1:03 pm
Londonmark offline
Restarting the server seems to have kicked it into life. Will keep an eye on it and see if it updates.
Thu Jun 09, 2016 1:05 pm
I'll check the plugin, maybe the issue is that the states didn't update after you made changes to the properties. If that is the case it should only fail to update right after a property change, and instead of restarting your server you could restart the LCD Creator plugin itself for the same results.
