Bugfix for Fibaro Motion Sensor (wrong temperature)
Sun May 22, 2016 2:45 am
davinci offline
I finally found a solution to stop the Fibaro Sensors (or Indigo) sending wrong sensor data:
The problem is that the sensor occasionally reports lux as temperature. That means either freezing at night or burning hot at day.
However at the same time this error occurs the sensor also switches the units from °C to F. This can be used to decide if you want to use the values or not. The next update of the sensor will reset this error. I just do this for every FMS and use the variable.
2015-06-07 08:12:13.740 Z-Wave received "Temperature 1" sensor update to 473 °F
2015-06-07 08:12:13.747 Z-Wave received "Temperature 1" units changed to °F
"Fire Alarm"
2015-06-07 08:22:04.920 Z-Wave received "Temperature 1" sensor update to 25.0 °C
2015-06-07 08:22:04.927 Z-Wave received "Temperature 1" units changed to °C
Please note: I'm not sure how or if this error can occur if you are using F.
dev = indigo.devices[IDDEVICE]  # Temperature Sensor
check = dev.states["sensorValue.ui"]
value = dev.states["sensorValue"]
if "C" in check:
    indigo.variable.updateValue(IDVAR, str(value))
    indigo.server.log("°C")
    indigo.server.log("F")
Sun May 22, 2016 6:52 am
Re: Bugfix for Fibaro Motion Sensor (wrong temperature)
Good workaround – thanks for sharing it with folks.
