hamw wrote:Very sorry to hear of your broken water pipe. I've put together a script that controls my water valve to prevent a catastrophic leak. This is different from just using a water sensor as it will stop a leak from a pipe anywhere in the house downstream of the meter. The valve is also controlled from Insteon leak sensors.
viewtopic.php?f=5&t=14955
This is the install thread for the water meter and valve.
viewtopic.php?f=5&t=9940
I'm sure there are a lot of water flow/valve solutions you could use, but this does work. Hope that may be of some help.
Thanks. I ordered from Smarthome their leak sensors and water flow cutoff. I may try to use with your scripts. I am having plumber install the valve cutoff as my homeowners seems like they will include in my claim.
