Thanks Dave - That's just what I needed.
Now I can update the other six sensors to the correct readouts.
import socket
import urllib2
url = 'http://192.168.1.181/details.xml'
socket.setdefaulttimeout(10)
f = urllib2.urlopen(url)
xml = f.read()
f.close()
print(unicode(xml))
4billl wrote:Dave -Everything is working as inputs correctly.
But I had another request: On a couple of the 4-chan analog 0-10V devices, I ordered some with LED & relay.
Is it possible to control the LED & relay in Indigo? I can toggle them from the OW Server IP. But when I try to configure a trigger event for the LED or relay, I get to your "Send Command to 1-Wire Device " and in the next box "Configure ...", I can select the Server IP and the Sensor ID, but what do I put in the Variable Name and Value? I tried both" owsLED" and "owsLEDState" with the value of "1" as that was the change I saw when toggling via the server IP.
But neither did anything.
Ideas?
<LEDState Writable="True">0</LEDState>
<RelayState Writable="True">0</RelayState>
