UrbanFarmer wrote:Glad you figured it out. Let us know how you use it.I think I've found it under "Phidget Stand Alone Device" - "PhidgetTemperatureSensor 4 Input"
UrbanFarmer wrote:First, a description of the formula syntax for the 0999C is in this post. As to whether that is the correct formula... the input to the formula is the output from the InterfaceKit - a value from 0 to 1000. Where 0=0volts=0psi and 1000=5volts=30psi. Therefore each value point = 0.03psi (30/1000). So I would think something like x*0.03 is what you want.I'm using x/33 and it seems to be working, but I have yet to thread in the pressure sensor into the pipe that has between 5 and 10 PSI. I have to shut down my system to do that.
Still would like to know if that is the right formula.
The problem I was having was solved by reloading the phidgets plugin a second time.
4billl wrote:You really should start the Phidgets Web service on the local machine (Phidgets Pref Pane) and then connect to the Phidget at the local address, 127.0.0.1. I think you will find that works much better and will still allow you to use the Phidgets Prefs pane Bonjour tab to access the display.I tried adding another new LCD directly to a USB port (a different kit & LCD serial number) . The Phidgets service in Systems Preferences can see the new (additional) LCD 1204/3655 and can even control and initialize it. And I can control the backlight. When I try to add a standalone Phidgets device, I can chose Configure Phidget LCD Screen Device, put in the Interface kit number, Select Local USB Port, but there is still no new USB serial port number.
4billl wrote:Even with the web service started and using the local address 127.0.0.1, I still get
Phidgets Plugin Error textLCD Exception (textLCD Error) 5: Phidget not physically attached.
(I can see and operate the LCD from the Sys Pref - Phidgets service.)
I am trying to just send status information (such as water tank levels) to display on the LCD without having to attach it to an SBC..
4billl wrote:It never shows up in the Bonjour pane.
4billl wrote:After starting webservice in the Phidgets Webservice pane, it shows it is running.
The LCD is not included in the Bonjour pane, but it shows up in General and Labels.
Users browsing this forum: No registered users and 17 guests
