[ANSWERED]Delayed iMessage based on device state
Thu Nov 12, 2015 3:13 pm
petematheson offline
Hi Guys,
I managed to delete my old trigger when switching devices over.
Could someone correct my script for me please?
I want to send an iMessage if the Garage Door is left open for more than 5 minutes.
I have the trigger defined as, If Garage Door state open = true, then run the following script (which has a delay of 5 minutes)
set GarageDoorOpen to state of device "Alarm_Garage Door"
if GarageDoorOpen = (open) then
tell application "Messages"
set theBuddy to buddy "Pete"
send "Garage door has been left open" to theBuddy
end tell
else
end if
The sending works fine - it's just the checking if statement I can't get to work. It says that it can't get the state of Alarm_Garage Door
Thu Nov 12, 2015 4:00 pm
Re: Delayed iMessage based on device state
I don't know what kind of device "Alarm_Garage Door" is, so I'm not sure what syntax will work for it...
Thu Nov 12, 2015 4:02 pm
Ah sorry, it's a wireless contact for my DSC alarm.
Screen Shot 2015-11-12 at 22.03.51.png (58.29 KiB) Viewed 6834 times
Screen Shot 2015-11-12 at 22.03.54.png (61.65 KiB) Viewed 6834 times
Screen Shot 2015-11-12 at 22.04.00.png (27.69 KiB) Viewed 6834 times
Thu Nov 12, 2015 4:51 pm
Well, assuming it's a relay device type (vs a custom device);
set GarageDoorOpen to on state of device "Alarm_Garage Door"
if GarageDoorOpen  then
    end tell
end if
Fri Nov 13, 2015 3:53 pm
Jay
Garage door WAS a tilt sensor - Pete has replaced it with an alarm contact sensor that the DSC plugin reports as a custom zone device with custom state 'state' with values 'open' and 'closed'.
Can AppleScript access custom states of custom devices - if so, what is the script for that?
Fri Nov 13, 2015 7:47 pm
durosity offline
AppleScript can't access custom states afaik, best bet would be either setup a trigger to copy the state to a variable
Sat Nov 14, 2015 3:40 pm
Ah ha. Well, that totally explains it. The tilt sensor was probably a standard relay (on/off) device, which AppleScript can see and check the "on state" of. Custom device states, however, aren't exposed to AppleScript (as durosity points out). I agree with him that creating a trigger that inserts the state into a variable is the easiest way to do it.
Sun Nov 15, 2015 1:51 pm
Re: [ANSWERED]Delayed iMessage based on device state
Ah gotcha. Could you correct my also script for a variable or do I just change the word device for variable ?
Mon Nov 16, 2015 12:12 pm
I don't know exactly what's going to be inserted into the variable since I don't know what the state value is, but the script will look something like this:
if value of variable "someVarNameHere" is "open" then
    end tell
end if
In the first line, replace open with whatever the actual value is. That's pretty close anyhow...
Thu Jan 07, 2016 12:40 pm
Hi Jay & All,
No dice on this one, after realising today that my garage was stuck half-open today and I received no text. Left open for half a day, lucky nothing useful was in it!
I'm using the following:
if value of variable "GarageDoor" is "open" then
set theBuddy to buddy "Pete Matheson"
end tell
end if
even if I set this to immediately (instead of delay by 5 minutes) then I don't get a text.
It works perfectly if I click the 'Run' button. But just doesn't seem to work if I click Execute Actions Now
Thu Jan 07, 2016 1:20 pm
Hmmm - I don't see how that's possible (pressing Run and it works, clicking Execute Actions Now doesn't). What shows up in the event log when you press the Execute Actions Now button?
Thu Jan 07, 2016 4:21 pm
Hmmm, execute actions seems to be working now! Although I've changed the variable to 'closed' for now as it's late / dark / cold to go test with it open.
I'll give it a try tomorrow with the door open and see what happens, weird!
Fri Nov 15, 2019 11:53 am
Sorry to resurrect an old thread, with the changes to Applescript - what do I need to do to achieve this same result?
Garage door opens (the trigger)
A few minutes later Indigo checks if the door is still open - if yes = send iMessage every 5 minutes until it's closed.
Fri Nov 15, 2019 2:47 pm
You might want to look at the iMessages plugin - assuming it does the notification part like you want, then you probably don't even need a script. When the door opens, enable a timer device for however long you want to wait. Create a trigger that executes when the timer expires to send the message. Have another trigger that stops the timer when the door closes.
