Help with XBMC integration
Sun Sep 13, 2015 9:59 am
Korey offline
Re: Help with XBMC integration
jens wrote:
is it possible and controlling Kodi on a Razzberry whith Indigo?
// Jens
Probably.
just put the Addon in the appropriate folder.
posting.php?mode=quote&f=5&p=102148#pr92934
Korey
Sun Sep 13, 2015 10:05 am
jens offline
didn't work Kodi didn't find the folder :(
Fri Dec 11, 2015 4:08 pm
durosity offline
tenallero wrote:
Apologies to be so late.
This link points to the documentation about my Roomba plugin:
https://www.dropbox.com/s/9ghepfwbxdaw0 ... plugin.pdf
Inside you will find the link to download the code and setup instructions.
Some notes about it:
English is not my language. So, apologies about any linguistic incorrection.
I have publish it as a PDF file, because I have not found the correct way to do it as a readable forum entry (mainly about including pictures from my desktop)
The code is open. I will find the way to publish it on github or similar.
This plugin is my first Indigo's plugin and my first lines of python code. I would like to thank to Dan Noguerol (https://bitbucket.org/whizzosoftware/in ... ddy-plugin), because his work around "irrigation caddy plugin" give me inspiration and confidence to start coding a python plugin for Indigo.
Also congratulate Matt and Jay with the well done work with Indigo. It has been a nice experience to develop an Indigo plugin and collaborate with Matt testing some Fibaro's zwave devices.
Stoffergoffer, you opened the thread. Next point will be about XBMC and PiFace plugin.
Regards,
Ramon
Hello!
The link for the roowifi plugin documents and download is just 404ing, is there an updated link for it?
thanks :D
Tue Dec 15, 2015 3:26 am
tenallero offline
Durosity,
I hope the link works now.
https://www.dropbox.com/s/lq17ebqadts1a ... n.pdf?dl=0
https://www.dropbox.com/s/z73ntc1w35jn6 ... n.zip?dl=0
I am sorry, but I promissed to upload the plugins to github. But, I did not find the time.
If somebody is interesed, I have abandoned Roowifi in favor of http://www.thinkingcleaner.com/
I have developed an Indigo plugin por think cleaner
Fri Dec 25, 2015 10:25 pm
durosity offline
oooh yeah i was looking at those. I'm yet to get a roomba but its getting higher up my priority list, i only wanted the plugin for the roowifi to remind myself what it can do.
Tue Dec 29, 2015 2:15 pm
durosity offline
tenallero wrote:
Durosity,
Out of interest do you still have the old RooWifi interface and if so would you be willing to sell it? I just bought my first Roomba so now i need a way to interface it with Indigo!
Mon Jan 04, 2016 5:32 am
yassi offline
Hi all,
can one please repost the KODI (modified) Add-On?
The Dropbox link isn't working, 404 error.
Thx,
yassi
Mon Jan 04, 2016 8:46 am
Korey offline
yassi wrote:
Hi all,
Thx,
yassi
Try this:
https://www.dropbox.com/s/0hmf507qw9exc ... 9.zip?dl=0
Korey
Mon Jan 04, 2016 10:36 am
yassi offline
Korey wrote:
yassi wrote:
Hi all,
Thx,
yassi
Try this:
Got it, thanks!
Sat Jan 23, 2016 1:01 am
haavarda offline
tenallero wrote:
Durosity,
I just got the thinkingcleaner module. Could you share your thinkingcleaner plugin? That would be very helpful!
Håvard
Sat Feb 20, 2016 8:32 am
tenallero offline
I have just published a "Thinking Cleaner" plugin
https://github.com/tenallero/Indigo-Thi ... eaner/wiki
Sun Feb 28, 2016 7:38 am
tenallero offline
I am in process of "normalize" my plugins.
So, I am publishing them on github
https://github.com/tenallero?tab=repositories
The work is done for XBMC, Ping and ThinkingCleaner plugins
The work will follow for the rest of plugins.
Every plugin will have its on wiki
XBMC Plugin:
I am trying to gather the modifications that other user has done to adapt it to their own systems and requeriments.
Like using json library instead of simplejson, add-on main loop for older XBMC (Eden on AppleTV?)
Can you help me in this "gathering" task?
If you want to try the "new" plugin, please make a previous backup of your Indigo system.
XBMC devices must be deleted and recreated
I would like to know if the new documentation format (github wiki) is ok.
The plugin is now at:
https://github.com/tenallero/Indigo-XBMC
And its documentation at:
https://github.com/tenallero/Indigo-XBMC/wiki
Thanks to all
Ramon
Sun Feb 28, 2016 10:24 am
Korey offline
XBMC Plugin:
Thanks to all
Ramon
Hi Ramon,
The new plugin works fine on Kodi 16.0
Documentation looks good as well.
Thank you!
Korey
Sun Feb 28, 2016 1:45 pm
tenallero offline
HI,
Just published a new release for XBMC plugin.
Just fixing some bugs for the Kodi Add-on.
Remember that for this plugin .. don´t forget to install the Kodi add-on
Sun Feb 28, 2016 1:48 pm
tenallero offline
Korey wrote:
Hi Ramon,
Thank you!
Korey, many thanks for checking the new release.
Page 6 of 8 1 ... 3, 4, 5, 6, 7, 8
Users browsing this forum: No registered users and 24 guests
