Latest version of EasyDaq plugin
Sun Aug 24, 2014 12:34 pm
zurich offline
Greetings - I am using the Easydaq plugin 1.0.11 that come with Indigo 5, is there a newer version of the plugin that I can use with Indigo 5?
thanks to you for help.
Sun Aug 24, 2014 4:59 pm
Re: Latest version of EasyDaq plugin
That is the most recent version that will run with Indigo 5.
There is a newer version included in Indigo 6, however, the changes aren't compatible with Indigo 5. The main change was this:
Release Notes wrote:
Added support for EasyDAQ DO24PRMx stacks for support up to 96 relays on a single USB port
Sun Jan 03, 2016 12:16 pm
xgeek offline
Hi Matt, Does indigo 6 now support the EasyDaq board using ethernet as the wiki indicates?
Mon Jan 04, 2016 6:55 pm
Are you referring to the EasyDAQ NET16PRMx board? We haven't tested one in-house. There are mixed reports of that one working:
viewtopic.php?f=93&t=12492
viewtopic.php?f=3&t=11027
Tue Jan 05, 2016 4:19 pm
xgeek offline
Matt,
Read the posts you provided. Thanks.
Was seriously considering the EasyDAQ network interface card as a solution, but don't want to invest if it is unreliable. I am now considering developing a plugin for the "ControlbyWeb" devices. Those things are rock solid but have no current indigo interface.
