Are you upgrading from a previous version you will have to delete your old Verisure devices and add them again., this i because I have had to make some changes in the devices.xml file.haavarda wrote:Hi, just downloaded the latest version, and I am getting the following error:
Something with the date format?Code: Select all
Reloading plugin "Verisure 0.2.5" Stopping plugin "Verisure 0.2.5" (pid 88239) Verisure Debug shutdown called Z-Wave received "Ventilation unit" energy total to 330.316 kWh Stopped plugin "Verisure 0.2.5" Starting plugin "Verisure 0.2.5" (pid 88249) Started plugin "Verisure 0.2.5" Verisure Debug startup called Verisure Debug Debug is set to: True Verisure Debug Checking status for all Verisure Devices Verisure Error Error in plugin execution runConcurrentThread: Traceback (most recent call last): File "plugin.py", line 91, in runConcurrentThread File "plugin.py", line 155, in _refreshAlarmStatesFromVerisure File "plugin.py", line 159, in _updateDevUI File "plugin.py", line 214, in secSinceLastUpdate File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/_strptime.py", line 325, in _strptime <type 'exceptions.ValueError'>: time data '' does not match format '%Y-%m-%d %H:%M:%S' Verisure Error plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds) Disabling plugin "Verisure 0.2.5" Stopping plugin "Verisure 0.2.5" (pid 88249) Verisure Debug shutdown called
Verisure Plugin
Re: Verisure Plugin
Re: Verisure Plugin
Hi, I just installed the plugin and I got a strange behavior.
It look like an infinite loop that just fills the log:
" Verisure Debug Checking status for all Verisure Devices
Verisure Debug Currently not logged in, try again.
Verisure Error Must enter Username and Password in Plugin Config
Verisure Error Must enter Username and Password in Plugin Config"
And when I try to configure the plugin I just get a loading ball and then Indigo crashes.
Is there any config file I can add the login details to?
Re: Verisure Plugin
I'm sorry it's not working, I'm woking on a fix that hopefully will be ready to night.reitoo wrote:Hi, I just installed the plugin and I got a strange behavior.
Re: Verisure Plugin
I want to test the update for 24 h before I release it but here is a beta version that hopefully fixes you issue.reitoo wrote:Hi, I just installed the plugin and I got a strange behavior.
Re: Verisure Plugin
Would it be much work getting the plugin to work with other regions? I'd like to add a feature request for that.lindehoff wrote:I have not looked in to that but I think you're right. I think only the following countries work: Sweden, Denmark, Norway, Finland, France, United Kingdom, Belgium, Netherland.lochnesz wrote:Sounds like a great plugin!
How does it work with support for Verisure in different countries. I have a Verisure alarm in Spain. The user account seams to be local, or maybe for a regional/group of countries?
Peter
Peter
Re: Verisure Plugin
This plugin heavily relies with Verisure MyPage, https://mypages.verisure.com. Witch other region are you thinking about and do they have an homepage in witch you can control the alarm from?lochnesz wrote:Would it be much work getting the plugin to work with other regions? I'd like to add a feature request for that.lindehoff wrote:I have not looked in to that but I think you're right. I think only the following countries work: Sweden, Denmark, Norway, Finland, France, United Kingdom, Belgium, Netherland.lochnesz wrote:Sounds like a great plugin!
Peter
Peter
Re: Verisure Plugin
Verisure Spain would be very nice to include. It can be controlled from their web https://customers.securitasdirect.es
Peter
Peter
Re: Verisure Plugin
To be able too write support for other Verisure sites one needs an account so that you can inspect the traffic going form the browser.lochnesz wrote:Verisure Spain would be very nice to include. It can be controlled from their web https://customers.securitasdirect.es
Peter
Re: Verisure Plugin
It seems like the plugin locked my Verisure account now.
If I try to login using the webpage it says that my account is blocked for 10 minutes.
No call from Verisure, but I have now disabled the plugin to see if the account is enabled again.
Re: Verisure Plugin
That's because Verisure had some problems yesterday. I have built a fail safe so the plugin sleeps for 10 minute if Verisure will have the same problem again. I'm currently testing the update, hopefully I will release the update later this weekend
Re: Verisure Plugin
Sounds great!
Re: Verisure Plugin
Hi. The verisure my Pages has a possibility to enable or disable auto locking of the door. Is this possible to add to the plugin? If there is a lot of of traffic through the door it would be nice to disable auto lock for 1 hour etc...
Thanks for a great plugin!
Håvard
Re: Verisure Plugin
Some pictures to show how this interface is illustrated on my pages.
- Skjermbilde 2016-01-10 kl. 11.59.22.png (30.98 KiB) Viewed 7790 times
- Skjermbilde 2016-01-10 kl. 11.59.10.png (29.45 KiB) Viewed 7790 times
- Skjermbilde 2016-01-10 kl. 11.58.50.png (19.62 KiB) Viewed 7790 times
Håvard
