Verisure Plugin
Thu Nov 26, 2015 10:47 am
DrLaban offline
Re: Verisure Plugin
The new version with Yale support works like a charm :) Nice work!
Thu Nov 26, 2015 12:11 pm
DrLaban offline
Re: Verisure Plugin 0.1.7
lindehoff wrote:
New version available 0.1.7
New Device Support
  • Smart Locks Yale Doorman
  • Mice Detector
New Actions
  • Update Lock Status, Lock and Unlock
Other improvements
  • Fix bug #1
  • Date are now in correct format
  • Fixes error when having a Smart Lock
  • Fixes error: Too many failed login attempts
  • Improves error handling
I get this error after the update. The unit which is the siren startet to report these errors. All other devices seems to be OK.
Unable to update device state on server. Device: Kjøkken - Temp - Verisure, Reason: 'ascii' codec can't encode character u'\xf8' in position 2: ordinal not in range(128)
Error IllegalParameterError -- device value type for state key sensorValue must be real
Did you change anything with the character set in the new release? I deleted the Device called "Kjøkken - Temp - Verisure" and created a new called "Kitchen - Temp - Verisure".
Seems OK now. Didn't have this problem in the previous version. It could be the Norwegian character Ø that is causing the problem.
Thu Nov 26, 2015 12:23 pm
jens offline
Re: Verisure Plugin
Must be that have same problem with ö in Sweden
Sent from my iPhone 6 using Tapatalk
Thu Nov 26, 2015 12:32 pm
lindehoff offline
I've added it as a bug, #10, and look in to it as soon as I can.
Did it work before the update?
Thu Nov 26, 2015 12:34 pm
DrLaban offline
Yepp, Not a problem before the update.
Thu Nov 26, 2015 1:00 pm
lindehoff offline
Yepp, Not a problem before the update.[/quote]
I think I found the bug, try this 0.1.8
Thu Nov 26, 2015 1:09 pm
DrLaban offline
Re: Verisure Plugin
Installed it and renamed the device again. Seems OK now :) You're fast!
Thu Nov 26, 2015 2:23 pm
jens offline
Re: Verisure Plugin
Thanks now IT works for me to :)
Skickat från min iPad med Tapatalk
Thu Nov 26, 2015 2:55 pm
haavarda offline
Re: Verisure Plugin
Working good with my setup as well. Thanks for the implementation of the lock!
Håvard
Fri Nov 27, 2015 7:26 am
DrLaban offline
Re: Verisure Plugin
I notice that this error was introduced in the latest version too
27 Nov 2015 11:40:03
Verisure Error invalid syntax (<string>, line 34), trying to relogging in
27 Nov 2015 11:47:13
27 Nov 2015 14:06:45
Happend a couple of times last night and three times today.
Fri Dec 11, 2015 5:12 am
lindehoff offline
Re: Verisure Plugin
I think this comes from verisure side. I've added the issue and will look in to it.
lindehoff offline
New version 0.2.5
New version available 0.2.5
Update Device Support
  • Alarm
New Actions
  • Update Alarm Status, Arm_Away, Arm_Home and Disarm
Other improvements
  • Fix bug #10
  • Updated to version 0.3.2 of Per Sandströms python-verisure module
  • Big code rewrite to support the new version of python-verisure module
Upgrade
To upgrade to this version you just double click the file.
You will have to delete the old Verisure devices and add the again, this i because I have had to make some changes in the devices.xml file.
Sat Dec 12, 2015 3:27 am
DrLaban offline
Re: Verisure Plugin
Just downloaded the latest version (0.2.5) and installed it but it states that it is 0.2.0 inside Indigo.
Sat Dec 12, 2015 7:29 am
lindehoff offline
Re: Verisure Plugin
Good catch, I uploaded the wrong file. I have now uploaded the correct one, please try again.
https://github.com/lindehoff/Indigo-Verisure/releases/download/0.2.5/Verisure.indigoPlugin.zip
Sun Dec 13, 2015 1:47 am
haavarda offline
Re: Verisure Plugin
Hi, just downloaded the latest version, and I am getting the following error:
 Reloading plugin "Verisure 0.2.5"
  Stopping plugin "Verisure 0.2.5" (pid 88239)
  Verisure Debug                  shutdown called
  Z-Wave                          received "Ventilation unit" energy total to 330.316 kWh
  Stopped plugin "Verisure 0.2.5"
  Starting plugin "Verisure 0.2.5" (pid 88249)
  Started plugin "Verisure 0.2.5"
  Verisure Debug                  startup called
  Verisure Debug                  Debug is set to: True
  Verisure Debug                  Checking status for all Verisure Devices
  Verisure Error                  Error in plugin execution runConcurrentThread:
  File "plugin.py", line 91, in runConcurrentThread
  File "plugin.py", line 155, in _refreshAlarmStatesFromVerisure
  File "plugin.py", line 159, in _updateDevUI
  File "plugin.py", line 214, in secSinceLastUpdate
  File "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/_strptime.py", line 325, in _strptime
<type 'exceptions.ValueError'>: time data '' does not match format '%Y-%m-%d %H:%M:%S'
  Verisure Error                  plugin runConcurrentThread function returned or failed (will attempt again in 10 seconds)
  Disabling plugin "Verisure 0.2.5"
  Stopping plugin "Verisure 0.2.5" (pid 88249)
Something with the date format?
Håvard
Users browsing this forum: No registered users and 27 guests
