- Posted on
Thu Jan 14, 2016 1:38 pm
johnpolasek
offline
Unless the one I got was defective, this thing has got some serious teething problems; Since I have a Vera Lite to control a Z-wave deadbolt, I bought one and decided to hook it up to the Vera to at least play with it a bit... and found that it would link, but then drop off line after a couple of hours. Spent a week going back and forth with Aeon, unlinking and relinking, changing parameters because "Vera does not understand this is not a 4 in 1 sensor" before I finally determined by trial and error that the motion sensor ONLY works when the device is on USB power, not when it is on battery, the light, temperature, and humidity sensors ONLY update when the device is on USB power OR when the activation switch is pressed on battery power, the UV sensor ALWAYS sends exactly the same value as the light sensor irrespective of the lighting source, and the device can only be updated when the activation switch is pressed , not when the sensor sends data to the Vera. The tamper alert does alwaystransmit when the device is moved. I've got a ticket in to Aeon to confirm that "this behavior is by design", but at the moment, I'd say that unless all you want to use it for is a shake sensor, or you're willing to leave it tied to a USB power source permanently, you're a lot better off sticking with the 4 in 1 (which I also bought one of and is working perfectly) even if it is a bit bulkier.
