Just to keep things in one thread, I'll post my screenshots here that match the syntax examples I gave above.
Gary_BBGames wrote:Hi Manders, whilst I can't answer your Reflector question I hope someone else here can.
Another solution is to use Home Remote: Remote. It's a relay from one copy of Home Remote (outside your network for example, to one inside your network, running on your same Mac Server as you use Indigo on).
You need to get the Mac version which is another £1.49 (but then you are covered for iOS, watch OS tvOS and OS X) and then set up Home a Remote: Remote on the iOS version. It will sync with the OS X version and they will communicate over a SSL secured socket connection. The action is never sent over the network, just an ID for it. You can set up an SSID black list in iOS app so that you don't send the remote command when you are already at homE, but when you are outside of the network it will relay the command to your home and call the action, with no port forwarding or exposure of your internal network resource to the outside world.
